Results 1 to 1 of 1
Thread: March 2022, V8.3.19 Public Release
    Default March 2022, V8.3.19 Public Release
    Attention:
    V7.5 no longer supports installation to Windows XP or Windows Vista. This change is due to SHA1 having been deprecated by digital certificate authorities. More info on SHA1
    V7.5 and V8 are now only supported on Windows 7, 8, 8.1 and 10.
    Full Release Notes:
    Attention:
    After updating FlashScan/AutoCal V3 devices to firmware V3.00.089, the V3 device will attempt to automatically update the boot block to V3.00.006. Please follow the instructions on the V3 device's screen to complete the boot block upgrade.
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V7 software: V7.5.46 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.3.19 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • FlashScan/AutoCal V3 Firmware: V3.00.089 (Mar 03, 2022), Boot Block: V3.00.006 (Feb 27, 2022)
    • FlashScan/AutoCal V2 Firmware: V2.08.187 (Mar 03, 2022), Boot Block: V2.08.009 (Feb 27, 2021)
    Download here:
    Known Issues:
    Issue #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Workaround: EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
    Regards,
    The EFILive Team
  1. January 2022, V8.3.18 Public Release
    Last Post: February 24th, 2022, 10:51 AM
  2. January 2022, V8.3.17 Public Release
    Last Post: February 1st, 2022, 02:31 PM
  3. January 2022, V8.3.16 Public Release
    Last Post: January 25th, 2022, 03:45 PM
  4. Oct 2017, Release Candidate 4 (AKA Public Release)
    Last Post: October 23rd, 2017, 09:17 AM
  5. Public release, March 29, 2012
    Last Post: June 22nd, 2012, 04:53 AM
