Results 1 to 2 of 2
Thread: Need 2016 Ram 2500 with AISIN transmission.
    Jan 2022
    Default Need 2016 Ram 2500 with AISIN transmission.
    How do I get a deleted file for my truck? When people do the deletes is there a "switch off" like in Euro stuff or even WARP/MM3 stuff or do people have to rewrite the code?
    Jul 2022
    These days most do not talk about deletes and I think there is actually some verbiage on "delete" topics within the forum rules. I know you're new but just putting this out there as a fair warning.
    To answer your question, EFI Live does not support deletes nor do they write/build/distribute any information as such. Now that said, EFI does support custom functions/tables which can be custom built so if you can get a hold of a binary and figure it out from there then you're already ahead of most. There is no switch off and honestly you would be lucky to get something of the sort for free even if it was available. Everyone wants money these days even if it's just for the information.
    Think of Warp and MM3 as GUI's. Someone took the time to figure out what needed to be disabled or changed then packaged that into a user friendly program.
  1. Ram 2500 Ori/Stock file
    By MPC-0000 in forum Cummins 6.7L
    Last Post: February 19th, 2022, 05:41 PM
  2. 2013 3500 Ram 6.7 with Aisin trans unable to read file
    By staytuned in forum Cummins 6.7L
    Last Post: June 18th, 2020, 10:37 AM
  3. 2020 brazilian ram 2500
    By romulo_sampaio in forum Cummins 6.7L
    Last Post: January 9th, 2020, 08:59 AM
  4. I would like to beta test for the 2019 Ram 2500 6.7L Cummins.
    By CumminsTwang in forum Do you want to be a Beta Tester?
    Last Post: August 5th, 2019, 12:47 AM
  5. Replies: 1
    Last Post: May 19th, 2019, 09:09 AM
