Results 1 to 2 of 2
Thread: CM2100 ROM Boot
    Aug 2019
    Default CM2100 ROM Boot
    Does anyone know how to get a CM2100 into rom boot while on the truck so PCM can be flashed with EFI Live?
    Mar 2022
    Someone correct me if im wrong but pretty sure you need bench harness as they use different pinout then factory Dodge harness. Just went through this and had to send out and bench flash.
  1. CM2100 5K Fueling
    By Twistedshafts in forum Cummins 6.7L
    Last Post: October 25th, 2021, 11:40 AM
  2. T43: 2007 Escalade (2) Roms: 22" Rom and 18" Rom Calibration Speedo Adjustment
    By raceghost in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 31st, 2020, 10:57 PM
  3. 05 Vett E-40 ECU P0601 ROM Error - New ECU Swap Question
    By brossjd in forum Gen IV V8 Specific
    Last Post: August 20th, 2017, 05:48 AM
  4. P0601 "Control Module Read Only Memory (ROM)"
    By WI Huck in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 23rd, 2009, 02:51 AM
