Results 1 to 9 of 9
Thread: New laptop issues
    Mar 2007
    Default New laptop issues
    Hey I have upgraded my laptop and its running windows11. I cannot run V7 scan or tune, They open show an error and close! I need to use V7 with my roadrunner can anyone offer a solution?
    Appreciate any help, Mike
    Jul 2003
    what error? screenshot? are you on the latest version for V7?
    https://download.efilive.com/Softwar...5.48_Setup.exe
    Mar 2007
    Yes I have the latest version and have un installed and re installed as well, here are a couple of screen shots
ID:	24114   Click image for larger version.
    In V7 goto settings and set the path names to the correct paths for each folder.
    Mar 2007
    As soon as I close the error message it closes the program
    Ok, do this: using the Window File manager/explorer, goto the folder you see specified in the error message, and create the file calc_pids.txt.
    Mar 2007
    Thanks I had to go back to my old laptop as nothing That I do seems to let me open and keep open V7. here is the user config that shows calc-pids being there but still no joy
    The path name has to ve the same as in the error message:
    c:\Users\Mike\Documents\EFILive\V7.5\User Configuration
    Note that ThisPC maps to C:\ which is not the same as C:\Users\Mike.
    Mar 2007
    Thanks Joecar, here is the fix (thanks Paul)
    Close down all EFILive software.
    Run "regedit" (click on start button and start typing regedit then select the "Registry Editor" option that appears.
    Locate the key: \\HKEY_CURRENT_USER\EFILive\Software\V7.5
    Delete it which will delete it and all its sub items.
    Close regedit.
    Restart V7.5
  1. New to EFI, and having Laptop issues
    By millerman04 in forum General
    Last Post: August 29th, 2010, 04:49 PM
  2. on the way but no laptop
    By dt.2448 in forum General (Diesel)
    Last Post: January 8th, 2009, 03:56 PM
  3. Need Laptop
    By jorge in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2008, 05:54 AM
  4. Handheld No Laptop
    By ViciousKnid in forum General (Petrol, Gas, Ethanol)
    Last Post: June 15th, 2008, 07:25 AM
  5. Laptop
    By Chevy366 in forum Lounge
    Last Post: February 16th, 2008, 04:10 AM
