Results 1 to 3 of 3
Thread: Ls1b $0281 $0101 $054a
    Oct 2021
    Default Ls1b $0281 $0101 $054a
    Trying to Cal flash a LS1B ECM and keep getting $0281 $0101 $054A Believe I possibly bricked one because of $0281 during a call flash. Was able to flash another and get engine running but tried to get back in and change trans to 4l60 and getting the same codes not all at once but different times.
    Had stereo on star and ABS fuses pulled, no other power draws, OBDII fuse is good.
    V8.3.21
    V3 Firmware V3.00.
    Bootblock V3.00.006
    Any help….
    Oct 2021
    Heres a trace
    The LS1 controller appears to be unresponsive and most likely unrecoverable due to the full flash failure.
    Contact SoCal Diesel, they can replace the flash chip on the LS1 controllers.
    https://www.efilive.com/distributors
  1. Code $0101
    By tytilidie in forum General
    Last Post: June 24th, 2021, 10:10 AM
  2. $0101 During Crank
    By RC1 in forum General
    Last Post: October 21st, 2019, 04:41 AM
  3. $054A Boot Loader Failed to Start
    By brentg454 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 10th, 2018, 11:49 AM
  4. Error 0101 code
    By Jaredlpickett1991 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 14th, 2015, 07:24 AM
