Results 1 to 3 of 3
Thread: April 23, 2022, V8.3.22 Public Release
    Default April 23, 2022, V8.3.22 Public Release
    Attention:
    V7.5.48 will be the final general release of the V7 software, no more updates (other than serious bug fixes and security fixes) will be released for the V7 software.
    Full Release Notes:
    Attention:
    After updating FlashScan/AutoCal V3 devices from firmware V3.00.088 to V3.00.089 or later, the V3 device will attempt to automatically update the boot block to V3.00.006.
    Please follow the instructions on the V3 device's screen to complete the boot block upgrade.
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V7 software: V7.5.48 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.3.22 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • FlashScan/AutoCal V3 Firmware: V3.00.090 (Apr 01, 2022), Boot Block: V3.00.006 (Feb 27, 2022)
    • FlashScan/AutoCal V2 Firmware: V2.08.189 (Apr 08, 2022), Boot Block: V2.08.009 (Feb 27, 2021)
    Download here:
    Known Issues:
    Issue #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Regards,
    The EFILive Team
    Jul 2003
    Thanks.
  1. April 10, 2022, V8.3.21 Public Release
    Last Post: April 9th, 2022, 04:32 PM
  2. April 2022, V8.3.20 Public Release
    Last Post: April 6th, 2022, 08:35 AM
  3. March 2022, V8.3.19 Public Release
    Last Post: March 3rd, 2022, 06:08 PM
  4. January 2022, V8.3.18 Public Release
    Last Post: February 24th, 2022, 10:51 AM
  5. January 2022, V8.3.17 Public Release
    Last Post: February 1st, 2022, 02:31 PM
