Results 1 to 1 of 1
Thread: May 05, 2022, V8.3.23 Public Pre-Release
    Default May 05, 2022, V8.3.23 Public Pre-Release
    Full Release Notes:
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V8 software: V8.3.23
    • FlashScan/AutoCal V3
      • Firmware: V3.00.091 (May 05, 2022),
      • Boot Block: V3.00.006 (Feb 27, 2022)
    Download here:
    Known Issues:
    Issue #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Workaround: EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
    Issue #2: Y-axis at the right of each chart are justified-right instead of left.
    Workaround: None, will be fixed in the next update.
    Regards,
    The EFILive Team
  1. April 23, 2022, V8.3.22 Public Release
    Last Post: April 23rd, 2022, 07:31 PM
  2. April 10, 2022, V8.3.21 Public Release
    Last Post: April 9th, 2022, 04:32 PM
  3. April 2022, V8.3.20 Public Release
    Last Post: April 6th, 2022, 08:35 AM
  4. January 2022, V8.3.17 Public Release
    Last Post: February 1st, 2022, 02:31 PM
  5. January 2022, V8.3.16 Public Release
    Last Post: January 25th, 2022, 03:45 PM
