Results 1 to 10 of 18
Thread: 4l80e Swap with COS5
    May 2020
    Default 4l80e Swap with COS5
    I have a turbo F-Body that has already been converted to OS 2020005 and I am looking to swap my 4l60e to a 4l80e. Can I still just do a segment swap from a truck with OS 12212156 since that is was 2020005 is supposed to be based on or do I need to go about it some other way? Also, if I can just segment swap it, does anyone know where I can get one for 12212156?
    I can send you a 0202005 COS5 with a 4l80 already segment swapped.
    May 2020
    Quote Originally Posted by nonnieselman View Post
    That would be awesome, thanks!
    Will a 5.3/4L80E work or do you need a 5.7 or 6.0 engine segment?
    May 2020
    It's a 5.7 but it shouldn't matter if I'm gonna have to copy over all the tables from my engine tune right? Actually, shouldn't I be able to export the trans segment and swap it with my current tune?
    Ah yea thats true. You can seg swap your engine data to it.
    This one also has the Min TPS TCC disabled So when you let off throttle it wont unlock converter like a stock 4l80 tune.
    May 2020
    Awesome! Thanks again!
    let me know if it works how you want.
    To answer your original question, you can do the 4L80E trans segments (2 segments, the trans segment and the trans dtc/error segment) on top of your COS5.
    But be sure to check/compare your tables before/after.
  1. segment swap in COS5
    By B18B1LS1 in forum Custom Operating Systems
    Last Post: June 12th, 2017, 09:08 AM
  2. 4l80e swap help
    By 05chevy in forum Petrol / Gas
    Last Post: February 8th, 2015, 03:08 PM
  3. COS5 with FBW and 4L80e
    By ttls1 in forum Gen III V8 Specific
    Last Post: July 8th, 2014, 10:45 PM
  4. Need blackbox 4L80E tune for my 4L80E segment swap
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 10th, 2013, 10:57 AM
  5. 4L80E swap
    By grec-O-face in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 3rd, 2008, 01:36 AM
