Thread: 04140003 OS and 4L80E ....Can it be done with segment swap ?
    Sep 2006
    Default 04140003 OS and 4L80E ....Can it be done with segment swap ?
    Hello Gents ,
    Currently have a vehicle which I had tuned previously using COS 04140003 (VZ 5.7) , owner has upgraded 4L60E to a 4L80E, I am aware of segment swaps requiring same base OS prior to switching to COS , but nil matching OS is available (12592433) .
    My question is - has anybody successfully carried out segment swap post COS or any other method , Im looking at adding CAX to add Transmission selection as per HPT ...But am still unsure if that work either .
    I dont really want to retune using HPT to make this work as EFILive is a much better product ....
    Any help would be appreciated .
    Kyle
    Hi Kyle,
    Do the transmission segment swap first, before upgrading to the COS.
    You may not find a matching OS with a 4L80E segment (mainly because only some trucks got the 4L80E, no cars).
    The CAX addition will need a known cax file (i.e. that contains known address(es))... are you saying HPT can change the transmission...?
    Aug 2006
    Can you post a copy of a 12592433 calibration? I have a cax for that parameter and put the hex address for that parameter of your OS in it. I don't have a calibration to check it out on.
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    Sep 2006
    Lextech .... As requested . Its an A4 Tune file .. I have M6 if required.
    Kyle
    Aug 2006
    Try this one. It has been switched with a cax file. It HAS NOT been proven. Remember that there are a few wires that need to be changed around when switching from a 60 to an 80.
    Jeff
    Dec 2015
    Quote Originally Posted by Lextech View Post
    Jeff
    epic thread ressurection here! did this file work? i am in the same boat
  1. T42 4l70e to 4l80e segment swap
    By dmaxvaz1978 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 14th, 2014, 04:00 AM
  2. Need blackbox 4L80E tune for my 4L80E segment swap
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 10th, 2013, 10:57 AM
  3. did segment swap to 4l80e have a question
    By Cool28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 3rd, 2011, 11:42 AM
  4. 4l80e segment swap!!!
    By hyderm87 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 14th, 2009, 03:28 PM
  5. 4l80e segment swap!!!
    By hyderm87 in forum Custom Operating Systems
    Last Post: May 12th, 2009, 03:29 AM
