Results 1 to 2 of 2
Thread: Occasional KR @ medium RPMs?
    Lifetime Member Garry's Avatar
    Jun 2006
    Default Occasional KR @ medium RPMs?
    OK, having the VE dialed in pretty decently I figure, I'd like some hint about the KR I keep seeing...
    OK, over a 30 minute logg, I get about 20 more or less short spans of KR .. I get them all over the place, with 800 rpm and 8 to 16% TP transition, around 1600-2400, or 4400+ RPM ... doesn't seem to occur at WOT at all ... WB AFR sometimes looks fine around 14.63, other times it's going up to 16/17 ... on some occasions, I notice the timing advance going down rather rapid due to increased TP, while other times everything seems rather stable ...
    Any idea? Check for some of the spikes in the attached logg ... (got the .pid-selection from the logg in the zip)
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
    Feb 2006
    Another one of your threads to follow with another similar problem. Could be burst knock but I'm not sure. Mines tends to happen while in higher gears like 4th-5th at low rpm trying to hit cells around the same areas you mentioned.
  1. RPMs bouncing at 2-3 shift!
    By shadyst in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 8th, 2009, 07:50 PM
  2. Tach is off by about 200 rpms. Can I change this?
    By mvvette97 in forum Gen III V8 Specific
    Last Post: January 22nd, 2009, 05:58 PM
  3. WOT then can't get RPMs
    By JOHNGEAR in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 14th, 2008, 03:31 PM
  4. shift rpms tis rpm or engine rpms
    By 69camaro5speed in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 25th, 2008, 07:01 AM
  5. Need more rpms
    By smknmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2008, 09:39 PM
