Results 1 to 3 of 3
Thread: May 09, 2022, V8.3.24 Public Pre-Release
    Default May 09, 2022, V8.3.24 Public Pre-Release
    Full Release Notes:
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V8 software: V8.3.24
    • FlashScan/AutoCal V3
      • Firmware: V3.00.092
      • Boot Block: V3.00.006
    Download here:
    Known Issues:
    Issue #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Regards,
    The EFILive Team
    Jul 2003
    I will test this release but,
    Fixed VIN change option on the CM2450B (CMF) controller - which was failing with error $0101 "No data received." if the "Clear DTCs before changing VIN" checkbox was checked (even when it was disabled)".
    this was also happening on e38s. it also happens on oil life change.
    The fix for the CMF was to simply not send the clear DTC command prior to changing the VIN - it caused problems on the Cummins platform.
    Is it possible that when you are updating the E38 you also need to check the "Obtain secure access" option as well?
  1. May 05, 2022, V8.3.23 Public Pre-Release
    Last Post: 2 Weeks Ago, 11:52 AM
  2. April 2022, V8.3.20 Public Release
    Last Post: April 6th, 2022, 08:35 AM
  3. March 2022, V8.3.19 Public Release
    Last Post: March 3rd, 2022, 06:08 PM
  4. January 2022, V8.3.18 Public Release
    Last Post: February 24th, 2022, 10:51 AM
  5. January 2022, V8.3.17 Public Release
    Last Post: February 1st, 2022, 02:31 PM
