Are you getting similar results after each log in your BEN map? If so, are you sure your MAF is disabled?
MAF is didabled. Could it be the cam?
Joe,Originally Posted by joecar
Last 2 BEN maps are in the other thread with Garry. Primary and secondary BEN maps, commanded AFR and LC-1 actual AFR listed in 2 seperate posts.
On my way to do another logs with latest changes.
Shawn
Hit it with the smooth hammer. Also you will likely find that you arnt hitting all cells so some of the peaks will be from there. Just hit smooth once.
As Joe says if your BEN's are 1 or close to it, then all is well.
2014 VF SV LS3 Maloo.
that looks a little like mine. I run is CLSD now -2 trims accross the board I was little lower than that but added 1% fuel to the whole table to be safe with the new shit gas.
Ok, smoothing is what scares me. Smooth the entire table? Which smoothing tool? I have to make another log run since I found out that my ECT connector vibrated off about halfway through the last log run and I overlooked it before making changes. The SES needs 2 start cycles before turning on and it came on when I went to log some more. That sent me back to check the entire log to see where it came off. About 25 mins into a 40min run. Make sure the plug clicks all the way on when you do H/C...lolOriginally Posted by ringram
Ah, ok, I just connected...Originally Posted by ViolatorTA
