Here is a complete DTC .cax file for a 2012 Cummins 68RFE OS 22.12.08.18/52.12.08.18
52120818 - DTC.zip
52120818 - DTC.zip
Wow, posting this file is a bit dangerous...
Thanks, Jim you are the best!
follow the directions in the conversion tool in the scan and tune v8 software and problem solved
My experience with EFILive is very limited and I have been attempting to research and learn as much information as I can. So...I've attempted to covert the .cax to a .cax8 file in order to apply this user defined file to V8. Thus far been unsuccessful.
I assume the file in its current form is intended for V7 and requires conversion for V8.
This error message appears every time I try to convert the file.
"52120818 - DTC.cax: [C0007] Access violation at address 01424261 in module 'EFILive_ScanAndTune.exe'. Read of address 00000028"
