Results 1 to 2 of 2
Thread: cm2200 stand alone dies after 3 seconds
    Mar 2022
    Default cm2200 stand alone dies after 3 seconds
    I am working on a 2010 6.7l cummins with the CM2200 ECU which I intend to swap into an 84 Chevy. The engine was nearly new but it came without a wiring harness or ecu. I bought a used ecu and wiring harness and have wired everything up. I have it set up on a run stand, and have wired in the following pins outs from the ecu.
    Pin 2 ground
    Pin 3 fused 12v
    Pin 4 ground
    Pin 5 fused 12v
    Pin 6 ground
    Pin 18 can low
    Pin 35 can high
    Pin 70 key on 12v
    Pin 71 key on 12v
    I connected fuel, accelerator pedal is not yet hooked up. After cranking the engine fires and runs for about 3 seconds then dies.
    Any idea what I need to do to get it to idle/run continuously? Could this be caused by an ecu skim? Do I need to reflash the ecu? Any ideas are most welcome.
    I'd like to get it running well on the run stand before swapping it in. There are no vehicle electronics to think about, I just need the engine to run.
    Thanks!
    May 2022
    What’s up brother
    Did you get that engine running?
  1. dashboard cutting out after few seconds
    By 5.7senator in forum EFILive V4
    Last Post: June 16th, 2013, 02:53 PM
  2. e38 standalone, starts and dies after 2 seconds max
    By miguelc in forum E37, E38 & E67 PFI ECM's
    Last Post: July 27th, 2011, 11:12 PM
  3. Help with Idling high for a few seconds.
    By nchristian in forum Gen III V8 Specific
    Last Post: February 2nd, 2011, 04:42 PM
  4. 0 to 100mph in 9 seconds?
    By emarkay in forum Lounge
    Last Post: September 5th, 2006, 02:53 AM
  5. BB Logging keeps shutting off after a few seconds
    Last Post: May 8th, 2005, 03:19 AM
