Results 1 to 4 of 4
Thread: 05 kodiak dsp5 tune identification
    Apr 2006
    Default 05 kodiak dsp5 tune identification
    i recently purchaced a 05 lly kodiak and it has a dsp 5 tune on it, im not a diesel tuner but can someone id what these tunes are? ie 40hp 80 hp tow ect i want to make sure they are mdt tunes and not just ldt tunes in the truck.
    Jul 2022
    There is no stranded practice on how the tunes are set up, for the most part its low to high. Without seeing the file itself there is no way to tell.
    Mar 2022
    I wouldn't say there's NO way to tell. With data logging, you can see how the truck is running and compare it to a stock tune.
    Jul 2022
    Quote Originally Posted by Lennydmaxguy View Post
    Yes, you could data log to see what your fuel, boost and on time is and I could tell you round about what the truck should be making with that setting. You could also send me the file and I can compare it others and tell you what is going on.
  1. controller identification
    By calif0rnia in forum General (Petrol, Gas, Ethanol)
    Last Post: August 29th, 2018, 03:57 AM
  2. In need of 2008 Kodiak 4500 stock tune
    By Rstowe in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 12th, 2014, 06:46 AM
  3. Cadilac ECM Identification Help Please
    By Duramax 6.6L in forum Gen IV V8 Specific
    Last Post: December 16th, 2009, 02:35 PM
  4. Valve Bounce identification logging
    Last Post: June 1st, 2007, 12:01 AM
