Thread: Help Calculated pids (filters)
    Aug 2018
    Default Help Calculated pids (filters)
    I'm having trouble "stringing" filters together in calculated pids
    I have successfully made individual filters for TP and ECT and tested on Maps..
    But when I try to have "TP">16 and ECT>65 I get various errors.
    One said function okay, but when I applied the filter to the Map it gave me am error
    Eventually I would like to have one something like:
    TP>25,ECT>160, Injector tip temp<160,not in fuel trim cell6"or" greater....
    But I can't even get 2 tied togather
    Forgive my lack of code writing
ID:	24144   Click image for larger version.
ID:	24145   Click image for larger version.
ID:	24146   Click image for larger version.
    Aug 2018
    Newbies...
    For anyone needing the VERY BASICS with Calculated Pids and Filters, this helped me a lot...
    #7 in the series is Boolean Math, I watched them all..
    I downloaded the the Visual Studio so I could practice along with the videos...
    https://www.youtube.com/watch?v=HDAE9OR28gY
    Jul 2003
    Very nice. You can use the sidebar. It does a lot of the work for you.
    For instance..
    This is my ETCTP WOT filter
    -- XFLT.ETCWOT
    return pid("ETCTP")>90
    Hi dhoagland,
    First, check that you are logging all the pids mentioned in the calc pids and filters that you're using.
    Second, you need to use the pid() call to enclose the pid strings (and you should simplify the pid strings)... i.e. like this:
    return pid("TP")>16 and pid("ECT")>60
    Third, when using if-else, a return causes the calc pid/filter to immediately exit... i.e. the second if-else will not be executed... so the filter is only checking one condition.
    Aug 2018
    Hi dhoagland,
    Second, in the if conditions you need to use the pid() call to enclose the pid strings (and you should simplify the pid strings)... i.e. like this:
    Thanks joecar!!!!
    I'm seeing what you are saying "stick with it"... Since I realized I could download the tune on my car, that is tuned in another platform, then scan maps developed from the tune file, this is really coming together for me...
    Now when I get a hold of Son in Laws Duramax I think I'll have a good starting point
    Jul 2003
    Hi dhoagland,
    Very useful.
  1. Calculated pids
    By x MadMAX DIESEL in forum Black Box Logging
    Last Post: June 22nd, 2018, 09:26 AM
  2. Calculated PIDS?
    By beav in forum Diesel
    Last Post: December 3rd, 2013, 04:19 AM
  3. V8 User Calculated PIDs
    By Ninety8C5 in forum Tips and tricks
    Last Post: November 17th, 2013, 08:21 AM
