Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 2020 cm2450b/aisin stock tune file
    Jun 2022
    Default 2020 cm2450b/aisin stock tune file
    Hello everyone, I've tried searching for a stock tune file for my 2020 RAM 3500 but didnt find anything. Is there a place that i can get this from or would someone be willing to sell it to me? Thank you in advance.
    Senior Member Jim P's Avatar
    Nov 2019
    I got a pile of them, what's the cal number on your ecm? It'll be an IA800xx.xx
    Post up that number and I'll attach a tune file for you.
    Jun 2022
    Thank you Jim P,
    My calibration number is IA80034.02
    Nov 2019
    Here you go.
    Jun 2022
    Thank you.
    Dec 2020
    Quote Originally Posted by Jim P View Post
    I have a 2019 with CM2450B/aisin. The cal number is IA80002.17. Do you have a stock tune that correlates to PCM version 52401932AK which the dealer installed due to TSB TSB 18-010-21?
    Thanks!
    Nov 2019
    Here is the .17 revision and the .21 revision which is CSP capable. Also have the .23 revision if desired.
    Dec 2020
    Yes to the .23 version. Thank you!
    Nov 2019
    Here's the .23 revision
    Dec 2020
    Thank you very much.
  1. CM2450B 68RFE Base File
    By Red Wasp in forum Cummins 6.7L
    Last Post: February 20th, 2023, 12:00 PM
  2. 2020 Cummins stock files
    By horst in forum Cummins 6.7L
    Last Post: February 20th, 2023, 11:59 AM
  3. 2013 3500 Ram 6.7 with Aisin trans unable to read file
    By staytuned in forum Cummins 6.7L
    Last Post: June 18th, 2020, 11:37 AM
  4. Aisin trans file into 68RFE ECM?
    By LBZoom in forum Cummins 6.7L
    Last Post: August 23rd, 2014, 04:15 PM
