Results 1 to 4 of 4
Thread: HELP - L83 Cammed 5.3 issues
    Member TorqueMonster007's Avatar
    Aug 2013
    Default HELP - L83 Cammed 5.3 issues
    L83 5.3, E92 ECM in truck. Cam is a GenV BTR Stage 3 truck cam. Kit came with 4* phaser limiter. All necessary components to go along with cam. Cam was installed dot to dot per BTR. Cam Phaser timing tables are input per BTR (this could have been told to me wrong). Literally just need to get truck cranked and to idle close to commanded RPM set points. Everything else is no issue, but this particular one has me beating my head against the wall. I am semi-familiar with the idle based torque and how it works instead of the Idle Air and Fuel like Gen3 & 4. Need it to crank and idle on its own so I can begin getting data to adjust everything else but will not idle without foot on throttle around 1000rpm. From what I have heard the adapts on this ecu's idle might would try and idle with stock cal but desired idle bumped up enough to start getting idle torque data but with TPS input I can't. Can anybody point me in the direction of what needs to be done to just get it to crank and idle? It may be something simple I am missing but I'm stumped for some reason with this particular issue and platform. Attached are both Stock and MOD files for reference.
    E92_JJ Jackson_MODCAM_04-10-22.ctz
    E92_JJ Jackson_Stock_02-9-22.ctz
    2024 3500HD (SRW) Duramax Denali Reserve
    2021 Ram 4500 Limited (Horse Hauler)
    2016 LML 2500HD Duramax High Country with a little help
    2022 Yukon Denali
    Aug 2013
    No body has any idea just for a ball park to look it over? I referenced had a LT 376 to look at and it appears I should be close. I am trying to make sure if it's owner installation error or a DTC I am missing or Torque issue? This is definitely no GEN3/4.
    2022 Yukon Denali
    I stay away from the Gen 5's. Too complicated for me. Gen 4 is a struggle in itself. I stick to Gen3's LOL.
    Where are you located?
    Aug 2013
    Quote Originally Posted by nonnieselman View Post
    South Carolina. I think I have some insight on direction but not 100% sure till it's tried.
    2022 Yukon Denali
  1. 2019 L83 and 6L80 Standalone
    By BrokenAxle in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 10th, 2022, 03:27 AM
  2. 2018 L83 5.3 Install
    By Mark B1 in forum V8 Tune Editor
    Last Post: March 10th, 2021, 01:42 AM
  3. is anybody driving the L83 with 6L90E swapped into anything?
    By v8vegaman in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 26th, 2019, 05:25 PM
  4. 2015 L83 Stand Alone
    By oreobadr in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: April 28th, 2019, 11:13 AM
  5. Cammed l31 Surging and in gear idle issues
    By HellKnightHicks in forum Vortec V6/V8 Specific
    Last Post: March 25th, 2013, 07:08 PM
