Results 1 to 3 of 3
Thread: Throttle position issue
    Aug 2016
    Default Throttle position issue
    Good day,
    I'm having an issue with an E92 swap and a lack of throttle movement. This is a '14 Silverado V6, using the original ECM and the Silverado pedal. I've logged what I believe to be all of the important throttle PIDS, and I see that my ETCPP1 and ETCPP2 positions are reading 100% at full throttle, but the TPDES never goes higher than 40%. I've tried this test with the car running and with it shut off, and I get the same result. I also had a look at any throttle limiting stuff I could think of, but found nothing. Does anyone have any other thoughts on where to look next?
    I've attached both logs, running and not running.
    Aug 2016
    Well that was easy! After I posted I decided to see if it had something to do with me failing the MAF while playing with VVE, and sure enough, as soon as I re-enabled MAF the throttle started acting exactly as I thought it should. Is there an easy explanation for that? Obviously if someone decided to do a MAF-less tune then the limited throttle would not be desirable.
    Thanks for posting your findings.
    Hmmm, interesting!
  1. Throttle Position (TP%)?
    By beav in forum Diesel
    Last Post: July 2nd, 2013, 12:32 AM
  2. Throttle Position readings
    By Strong05 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: April 7th, 2013, 03:19 PM
  3. Throttle Position
    By bstuder11 in forum Gen IV V8 Specific
    Last Post: April 8th, 2012, 12:12 AM
  4. Throttle position Pid
    By zbadestz in forum General
    Last Post: February 26th, 2012, 01:52 AM
  5. Throttle position confuddlement
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: June 2nd, 2010, 07:18 AM
