Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 2021 csp5
  1. #11
    Mar 2022
    So if I have a customer currently running a cp4 tune and goes for the cp3 recall. It will require a new base file to match that pump? Or can the FCA current flow just be changed? I know I had a few LML trucks that were able to be adjusted easily. But seems like the Cummins are different?
  2. #12
    Jan 2010
    If you read a file with the another software suite there are a bunch of values that are different. A 2021 truck with the "CP3" flashed with a 19-20 OS for a CP4.2 doesn't run very well
  3. #13
    Nov 2009
    Did you log it to see why? I know of a 20 truck with a cp3 that runs well with the cp4 calibration but he does say it doesn't feel "as strong" as his previous similar setup. I have not had chance to log it but I would imagine it would be evident in the the desired vs actual pids.
  4. #14
    Jan 2010
    Quote Originally Posted by got boost? View Post
    Nah it ran so bad didn't want to keep it running. Modified the file this AM and flashed the truck his afternoon & it runs great with the correct pump data from the 2021
  5. #15
    Nov 2009
    You just use a noncsp file then I guess?
  6. #16
    Jan 2010
    No 19-20 CSP OS with the pump data inserted
  7. #17
    Mar 2022
    So what pump data parameters is changed? I wonder if they will make those parameters available to be viewed/changed VIA EFI software and not have to use 3 party programs.
  1. April 2021, V8.3.5 RC 3
    Last Post: April 21st, 2021, 05:27 PM
  2. April 2021, V8.3.5 RC 4
    Last Post: April 20th, 2021, 10:25 AM
  3. April 2021, V8.3.5 RC 2
    Last Post: April 6th, 2021, 06:11 PM
  4. March 2021, V8.3.5 RC 1
    Last Post: March 28th, 2021, 07:43 AM
  5. March 2021, V8.3.5 Beta 7
    Last Post: March 24th, 2021, 07:57 PM
