Page 3 of 3 FirstFirst 123
Results 21 to 21 of 21
Thread: reduced engine power after 3bar install
  1. #21
    Member tazinhawaii's Avatar
    Apr 2006
    Why does your boost VE table drop by 100 at 285 kpa?? This could be the problem I think. I've done this by forgetting to select the last row of a table while editing before and pulled my hair out trying to figure out what's wrong.... I imagine the PCM is trying to compute airflow at 14+ psi with the 0 psi VE numbers in the 285kpa column of this table....
    Also, what setup are you running? Just curious because it sounds/looks like you are very similar to me (2001 Z06, 427 C5R, PTS twin turbo, 60# injectors, etc.)
    Derrick
    1969 Camaro, LS3, 4L80E, Dana 60 rear, Air Ride, 19 and 20" wheels, Baer Brakes, and a lot more.
    2008 Charger SRT-8 Super Bee, Exhaust and Cold Air kit (Wife's car)
    2007 Yukon XL Denali, Family Hauler
    http://s330.photobucket.com/albums/l...i/69%20Camaro/
  1. P1514 Reduced Engine Power.
    By Mort in forum Gen III V8 Specific
    Last Post: April 2nd, 2009, 12:51 PM
  2. Reduced engine power
    By redlinepd in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 7th, 2007, 08:30 PM
  3. Reduced engine power after autoTune
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 15th, 2006, 07:08 AM
  4. SD mode = reduced engine power
    Last Post: February 18th, 2006, 12:19 AM
  5. Reduced Engine Power while MAFless
    Last Post: December 20th, 2005, 04:08 AM
