Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: injector flow rate table
    Feb 2005
    Default injector flow rate table
    Just wanted some clarification. The injector flow rate table is a correction for the injector flow rate as a function of pressure (MAP). This correction is because injectors are calibrated at atmospheric pressure but in the engine, they are under varying levels of vaccum?
    Jul 2004
    That would be correct.
    Ira
    Senior Member PSWired's Avatar
    Jan 2005
    I am guessing IFR tables are only used on returnless fuel systems where there is no vacuum references FPR?
    1995 GMC Yukon 4WD 4DR
    5.3 "LMG" engine: E85 with AFM
    6L80e 6 speed automatic transmission
    My understanding of this subject (...ha...)...
    The IFR table tells the PCM how much fuel mass the injector flows as a function of vacuum (i.e. BARO - MAP).
    Injector flow rate depends on the pressure difference accross the injector: on one side of the injector there is manifold pressure (MAP), and
    on the other side is [constant] fuel pressure plus atmospheric pressure (since fuel pressure is measured relative to atmospheric pressure);
    i.e. diff = FP + BARO - MAP, where FP = constant
    At WOT, injector flow rate is less (MAP is high), and to spray a specific mass of fuel, the PCM needs to keep the injectors open longer;
    At idle, injector flow rate is more (MAP is low), and to spray a specific mass of fuel, the PCM needs to keep the injectors open shorter;
    i.e. time(s) = mass(g) / flow_rate(g/s)
    Since the pressure regulator is not MAP referenced (in our case, "returnless system"), the PCM uses the IFR table to compensate
    for the variation in injector flow rate caused by the variation of MAP;
    But, if the pressure regulator were MAP referenced, the regulator would increase fuel pressure as MAP increased, causing the pressure
    difference across an injector to always be constant regardless of MAP variation, and in this case the IFR table would be flat with no slope;
    i.e. diff = FP + BARO - MAP, where FP = constant + MAP, so diff = constant + BARO
    EFILive Distributor dfe1's Avatar
    Jan 2005
    The IFR table is simply the electronic equivalent of a vacuum line running between the intake manifold and the pressure regulator. Trucks have a vacuum referenced pressure regulator so the IFR table is a straight line.
    Lifetime Member Rich Z's Avatar
    Quote Originally Posted by dfe1 View Post
    Sorry about bringing this old thread back to life, but I'm a RAW newbie at this tuning stuff and am sticking my toes into the water (timidly, I might add) by looking over the tune that was done on my car and then comparing the tables against a stock tune.
    Now if I understand the above quotes, then a car using a fuel pressure regulator that is MAP referenced (which mine is), then the IFR table should be a flat horizontal line. Is that correct? Well, I'm looking at the IFR table in my tune, and I see this:
    So obviously I am confused. The car seems to run fine except for some low RPM issues, but I would think that a MAP referenced fuel pressure regulator combined with changes in the injector pulse width forced by such an IFR table would give me some substantial issues.
    What am I missing here?
    CorvetteFlorida.com
    2002 Corvette Z06
    427 RHS block built by LME
    STS rear mounted twin turbos
    It nearly died on the operating table, but I'm bringing her back.
    Spot on, that's the best summary I've seen.
    Junior Member daveb's Avatar
    Feb 2005
    I am wondering why the configs only go from 0-80 Kpa in the ifr tables, which is less than 1 bar.
    What do you do when using forced induction?
    Quote Originally Posted by daveb
    Thats 0-80kpa of vacuum , for forced induction the whole maps need to be rescaled.
    VAC = BARO - MAP
    where
    VAC = vacuum
    BARO = barometric pressure (1 ATM, 1 bar, 100kPa approx, 15psi approx)
    MAP = manifold absolute pressure
    and since when MAP goes below 20kPa (VAC goes above 80kPa) the PCM cuts fuel (...correct me if I'm wrong...) so the PCM does not need the the injector flow rate below MAP 20kPa (which is VAC above 80kPa).
  1. B4001 Injector Flow Rate table help
    By kwhiteside in forum Gen III V8 Specific
    Last Post: June 30th, 2009, 11:45 AM
  2. injector flow rate table
    By stripes in forum Gen III V8 Specific
    Last Post: May 18th, 2008, 05:44 AM
  3. Injector Flow Rate correction of VE Table
    Last Post: February 12th, 2006, 03:14 PM
  4. Injector Flow Rate Table
    By WicketMike in forum General (Petrol, Gas, Ethanol)
    Last Post: December 31st, 2005, 07:21 AM
  5. the injector flow rate table..
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: August 10th, 2005, 02:17 PM
