Results 1 to 3 of 3
Thread: V8 maps
    Senior Member JUSTASBC's Avatar
    Aug 2010
    Default V8 maps
    I have not been using EFI Live as much as I used to. When I used to use it I used V7.5, and logged through it. Now I see there is a V8 scan and tune to use. I am surprised that it does not come loaded with MAPS. Is there a place I can download maps. It seems quite time consuming to build maps.
    05 Joe Gibbs black RCSB ram air hood, Leer tonneau, blacked out tail and head lights. Forged 370, Eagle crank, Wiseco pistons, Compstar Rods, Pro Flo XT intake, KB Racing log, spool valve, T6 S480 1.32 A/R, boost activated cutout, TSP 2.5 5.3l heads, Comp Cam 224/230 .600 with rockers, comp cams 1.75 roller rockers, dual Walbro 450's, Injector Dynamics id1300's, 4l80e w/3200 multidisk Circle D, trutrac w/3.73's, 3"DI/DO Magnaflow, tips through the roll pan, running COS3 Semi OLSD OS#12592618
    Its not terrible to do once you figure it out.. After getting use to V7.5 and switching over to V8 its kind of a shock.
    What kinda maps are you looking for? i can send you the list of the ones i have if it helps.
    Jul 2003
    V8>>>>>>>>>>>>>>>>>V7... and this comes from a V7 die hard fan... force your way though it.
  1. Maps?
    By EagleMark in forum General
    Last Post: August 25th, 2012, 04:33 AM
  2. Maps
    By limited cv8r in forum EFILive V4
    Last Post: August 6th, 2007, 09:26 AM
  3. hp and tq maps
    By southern in forum General (Petrol, Gas, Ethanol)
    Last Post: July 5th, 2007, 04:10 PM
  4. 7.4 maps
    Last Post: April 1st, 2007, 06:33 PM
  5. Is 7.2.3 going to have more MAPS?
    By BowlingSS in forum General
    Last Post: August 10th, 2005, 03:30 AM
