Results 1 to 4 of 4
Thread: Flash scan v3
    Jul 2022
    Default Flash scan v3
    I have an 08 lmm and am curious if i need to buy the autocal as well as the flashscan to create my own tunes or if i can just do everything with the flashscan? Also am curious if i need to buy the $400 gm tuning option? Thanks for your time!!
    Buy a FlashScan V3 ( https://www.efilive.com/flashscan-v3.html) and you need to add the GM Tuning option ($625 + $400), you will have all hardware (and software) needed to tune your truck. FlashScans create tunes and can flash unlocked tunes. AutoCals are to send tunes to customers (usually used by tuning shops) and can only flash tunes from a single FlashScan V3 at a time.
    Jul 2022
    Awesome thanks. Also is there a limit to the amount of tunes that you can make with the flashscan? I’m new to this and am wanting something where I have the ability to play around with it. Thanks
    No there is no limit to the number of tunes you can create.
  1. flash scan v2 problems
    By tcole in forum General
    Last Post: May 10th, 2018, 04:29 AM
  2. Replies: 2
    Last Post: June 2nd, 2017, 04:34 PM
  3. not so sure i was sent the correct v2 flash scan...
    By subiracer06 in forum FlashScan V2
    Last Post: September 29th, 2012, 01:16 PM
  4. It's been a while since I used flash scan
    By billyjo in forum Petrol / Gas
    Last Post: September 8th, 2012, 04:42 PM
  5. flash scan for gauges
    By crash85 in forum FlashScan V2 BB Logging
    Last Post: November 26th, 2010, 08:24 AM
