Results 1 to 5 of 5
Thread: Stock (clean) OS 11720604
    Aug 2018
    Default Stock (clean) OS 11720604
    Anyone have a Stock file for OS 11720604... Calibration ID 72350435AQ
    2007 Ram 2500 Federal Automatic 4x4
    Downloaded Tune attached was returned to stock from a box tuner that I want to rule out as the issue
    Thank You
    Senior Member Jim P's Avatar
    Nov 2019
    Closest I have is a 72351435BH, so I couldn’t do a compare to see if there was anything funky in your read out file. I can post up the 72351435BH if you want to try using that.
    Aug 2018
    Quote Originally Posted by Jim P View Post
    Thanks Jim
    I'll get back to ya. I think I'm going to try to flash from Mopar TSP
    Aug 2018
    So a PSA for people wanting to use wiTECH 2.0
    Your 2534 pass through, needs a minimum of 3 CAN channels. My GM MDI and Nexiq usb do not...
    I have a Controller Technologies Corp. Pulsar on the way
    Supports 4 CAN, Lin Bus, ETC...
    Aug 2018
    Here is the file that was Generated from Mopar TSP for this Truck if it might help someone.
    The OS changed. I'm not sure what to think about that.
    The Calibration ID stayed the same, except for the updated letters at the end
  1. Clean Stock LB7 OS
    By WisconsinHick1 in forum Duramax LB7
    Last Post: August 18th, 2018, 12:04 AM
  2. Clean Stock Tune Needed
    By WisconsinHick1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 11th, 2014, 09:42 AM
  3. Clean stock file for an 08 5500 C&C
    By blklmm in forum Cummins 6.7L
    Last Post: August 14th, 2013, 12:45 AM
  4. Need clean stock tune for 06 5.9L os 409
    By billybob in forum Cummins 5.9L
    Last Post: October 10th, 2012, 10:34 AM
