Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 2018 68 CM2350B Stock File
    Jul 2022
    Default 2018 68 CM2350B Stock File
    Does anyone have a stock file for the following:
    2018 68rfe
    D090066.03
    Jul 2022
    Thank you!
    Senior Member Jim P's Avatar
    Nov 2019
    That files only been posted on the forum a half dozen times or so lol
    Jul 2022
    Quote Originally Posted by Jim P View Post
    Still learning and I also found the OneDrive.
    Thanks for the patience .
    Jul 2022
    Jim, do you have a CAX for DTCs?
    Nov 2019
    The ones I’ve got posted on the forum
    Nov 2019
    FYI, if you are attempting a delete, turning DTC’s off is not enough.
    Jul 2022
    Well known, just trying to learn.
    Nov 2019
    Each and every calibration and revision has different sized fault tables and the addresses to them are different from calibration to calibration and revision to revision. There’s a table that says which fault codes are in the specific calibration/revision, an error index table/path table, some faults have more than 1 fault path, then there’s the MIL table that matches the error index table and the J2012 “P code” table that matches up a P code to a fault in the index table. They are all 16 bit unsigned integers.
  1. 2018 2350 Aisin Stock file
    By DaneF in forum Cummins 6.7L
    Last Post: June 16th, 2022, 06:34 PM
  2. Stock file for 2018 G56 Ram
    Last Post: April 13th, 2022, 01:33 PM
  3. 2018 dodge cme stock file
    By G60golf in forum Cummins 6.7L
    Last Post: April 4th, 2022, 01:14 AM
  4. cm2350b, ref trans stock file
    By agentr14 in forum Cummins 6.7L
    Last Post: February 19th, 2022, 06:39 PM
  5. 2018 Camaro Stock File OS 12688025
    By kangsta in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 13th, 2020, 11:48 AM
