V8.3.28 Public Release
Full Release Notes:
Version Numbers:After installing this release you should have the following software and firmware versions installed:
- EFILive V8 software: V8.3.28
- FlashScan/AutoCal V3
- Firmware: V3.00.096
- Boot Block: V3.00.006
Download here:
Known Issues: Issue #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
Issue #2: The "What's New" document shows the EFILive V8 software version as V8.2.28 instead of V8.3.28.
Workaround: Just assume it says V8.3.28
Regards,
The EFILive Team
