Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 69
Thread: 2022 Cummins Support
  1. #51
    Oct 2016
    Using the 19 cal but yes same thing. And yes theres stuff outside of efilive needed to use to full potential on cp3 truck
  2. #52
    Nov 2022
    Quote Originally Posted by Bigxrig98 View Post
    Bit more to it then that unfortunately. Need few extra things to make security happy etc. If its 68rfe truck will need converter pi curve programmed as well. Any 19-21 file will work as well with enough messing around. my 22 runs efi CSP5.
    When you say a few extra things for security, other than the VIN, is it done on the ECM or is it additional programming on another module? Can you shed some light?
  3. #53
    Oct 2016
    All in ecm programming. To make what the other modules see for “keys” match.
  4. #54
    Nov 2022
    Does the key information need to be extracted from the original ECM? Or the TIPM? Can it be done with EFILive or switch to Witech?
  5. #55
    Apr 2020
    I tried many times can never get the key to work could you help how make it turn on ? 19-21 ecm on a 22
  6. #56
    Nov 2022
    Quote Originally Posted by BYTES View Post
    I'm currently working on the same issue. Tried multiple ECMs (19-21) on a 22 and getting a security no start. Have you tried relearning the keys? I think that could be a possibility.
  7. #57
    Apr 2020
    We tried with Witech and the secret code straight from dealer, same shit wont start
  8. #58
    Nov 2022
    I have 3 19-21 that lose the VIN when installed on the truck. VIN shows all 0's. We try to update the VIN with EFI and shows it was complete but when we double check it, it still shows as all 0's. Hoping we can get this figured out. Do the keys need to be relearned into the new ECM?
  9. #59
    Jul 2018
    I believe the "secret code" cant be obtained from the dealer anymore. Have to have a NAFTA ID to be able to program keys/codes. Ran into it when programming a replacement PCM on a flood truck.
  10. #60
    Mar 2021
    Hi guys.
    I need original file from CUMMINS QUICK SERVICE for this vin's:
    3C6UR5FL4NG243178
    3C6UR5FL1MG673040
    I will try write this files in ECU 2019 for try tuning RAM 2022
  1. 2022 cummins updates?
    By Rutan in forum Cummins 6.7L
    Last Post: December 27th, 2021, 10:37 AM
  2. 2022 Cummins Support
    By Orange Stroker in forum Cummins 6.7L
    Last Post: October 25th, 2021, 05:16 PM
  3. 19 Cummins support?
    Last Post: April 18th, 2019, 11:16 AM
  4. Any Cummins support
    By 80superbu in forum General (Diesel)
    Last Post: October 15th, 2018, 02:00 PM
  5. 03-05 Cummins 5.9L Support
    By cindy@efilive in forum Cummins 5.9L
    Last Post: February 7th, 2015, 06:59 AM
