Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 69
Thread: 2022 Cummins Support
  1. #41
    Jan 2023
    The 2022 ECMs have an updated boot block that enforces a digital signature check that cannot be bypassed.
    The 2021 ECMs have a boot block that contained a "bug" that could be exploited to bypass the digital signature - Cummins fixed that bug in the 2022 boot block update.
    So no, you can't use 2021 ECM to gain access to a 2022 ECM, the only way would be to change the boot block in the 2022 back to the 2021 boot block, but you can't do that until/unless you supply the correct digital signature (or bypass it, which cannot be done).
    Warning: Getting your 2021 ECM flashed at a dealer can update the boot block to the 2022 boot block thus rendering the ECM no longer tunable.
    So basically if dealer flashes the 2021 ECM you WILL be locked out or will possibly be locked out?
  2. #42
    Quote Originally Posted by Sonoferick View Post
    Possibly locked out - we have heard of it happening (anecdotally) but have not confirmed that it happens.
  3. #43
    Nov 2022
    Is there a way to check if the Boot Signature has been updated without trying to flash the ECM?
  4. #44
    Quote Originally Posted by fr33kst3r View Post
    Unfortunately it appears Cummins did not implement some of the OBDII commands correctly that are used to obtain the boot block version number, so unfortunately there is no easy way to know.
  5. #45
    Nov 2022
    So the option is to use a 19-21 for a 22 Cummins flashed with the calibration and VIN of the 22. Will this work and is there anything else that needs to be programmed to get it to work?
  6. #46
    I don't know if that will work. It is not something that EFILive has worked on, tested or explored.
  7. #47
    Oct 2016
    Bit more to it then that unfortunately. Need few extra things to make security happy etc. If its 68rfe truck will need converter pi curve programmed as well. Any 19-21 file will work as well with enough messing around. my 22 runs efi CSP5.
  8. #48
    Nov 2009
    Quote Originally Posted by Bigxrig98 View Post
    Are you running one of the two OS that efi live currently supports csp5 on the 5th gens?
  9. #49
    Oct 2016
    Correct
  10. #50
    Nov 2009
    Correct
    So let me get this straight real quick. You're using OS 52.20.03.00 that is associated with cp4 based calibration ID's on a cp3 truck? Any editing outside of efi live done for cp3 to function correctly? Thank you for your help.
  1. 2022 cummins updates?
    By Rutan in forum Cummins 6.7L
    Last Post: December 27th, 2021, 09:37 AM
  2. 2022 Cummins Support
    By Orange Stroker in forum Cummins 6.7L
    Last Post: October 25th, 2021, 04:16 PM
  3. 19 Cummins support?
    Last Post: April 18th, 2019, 10:16 AM
  4. Any Cummins support
    By 80superbu in forum General (Diesel)
    Last Post: October 15th, 2018, 01:00 PM
  5. 03-05 Cummins 5.9L Support
    By cindy@efilive in forum Cummins 5.9L
    Last Post: February 7th, 2015, 05:59 AM
