Results 1 to 2 of 2
Thread: 2013 silverado 5.3 grade braking adjustment
    Aug 2022
    Default 2013 silverado 5.3 grade braking adjustment
    I am working on a 2013 silverado 5.3 that is having very aggressive downshifts in grade braking mode/in towing mode after a tune from a local shop. It enters grade braking prematurely and is very aggressive with downshifts while using towing mode. What tables do i need to look at/adjust to help solve this issue? If anyone has a stock file for a 2013 5.3/6l80e could you share that as well? i cannot seem to find a repository for efilive.
    These are the first 2013s i found on my laptop. T43 is stock. CD 2013 T43 isnt stock.
  1. Firmware down grade V2
    By derkscustomcars in forum FlashScan V2
    Last Post: May 20th, 2019, 07:20 AM
  2. Needed - 2013-2014 Silverado/Express 6.0L stock file
    By gixxer92 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 28th, 2017, 07:24 AM
  3. Brake Tap Grade Braking
    By killerbee in forum Duramax LLY
    Last Post: October 7th, 2009, 03:51 PM
  4. Engine braking
    By Rich in forum Gen III V8 Specific
    Last Post: December 26th, 2008, 08:48 PM
