Results 1 to 10 of 10
Thread: 2007 TBSS Stock Tune...Anyone have one?
    Jun 2021
    Default 2007 TBSS Stock Tune...Anyone have one?
    Good morning! I am looking for a stock tune for a 2007 TBSS. OS is for 12614654 this is an E67 PCM.
    If no one has one, is it possible to pull the tune from the factory PCM with the Flashscan V3?
    I wonder, any chance EFiLive has a "Tune Library"?
    Any help here would be GREATLY appreciated.
    Thanks!
    I dont see that OS in the tune library but its pretty old.
    Jun 2021
    So can I pull the stock tune out of the stock PCM?
    Jun 2021
    OK I pulled the stock tune from the stock PCM, but when I try to load it into the new PCM the OS doesn't match. How is that possible if the PCM is blank?
    Well, is the new one a NEW one from GM, or is it 'new' as in new to you snd from a wrecked vehicle? If the former, it may need to be programmed with SPS before efilive can flash it, if the latter, it may be a hardware/os combination that is incompatible with your original hardware/tune.
    Sent from my Pixel 5 using Tapatalk
    Latest 07 TBSS OS for the ECM is 12611938, never seen that 12614654 on a TBSS yet.
    To chime in with Cougar, what are you trying to do? If you're trying to flash any E67, you need to use GM SPS AND confirm the ECM hardware is actually compatible with the OS you're trying to use. In the case of an 07 TBSS, you have to use an 06-07 E67 only.
    Jun 2021
    Basically, I had what I thought to be an ignition switch issue. I replaced it and the NSBUS with no fix to my problem which was the truck dying in me while I am driving and wont start for several hours. So I printed out the flow charts and found it to be a faulty PCM.
    So I bought a new PCM and thought I'd buy a license and flash it myself instead of bothering with the dealership. So I pulled the program off of the old PCM and tried to install it to the new PCM but it wont even turn over.
    So I am assuming that I have the wrong idea of how this works. I do not know what SPS is.
    Quote Originally Posted by tytilidie View Post
    SPS is GM Dealership stuff.
    Basically your new PCM doesnt have a "Image" on it.
    The tune you read off your old PCM really isnt all the data you need for a new pcm. There are things in the background you cant see.
    Jun 2021
    So, take the vehicle to GM and let them install it all?
    Yep take them the truck and ask for a ECM Update. It is usually $100 to $150 for them to spend 5 minutes to flash it.
    Then you can read it off and have fun.
    If you have a buddy at a dealership they usually will update it for $40.
  1. Replies: 8
    Last Post: February 21st, 2022, 03:36 PM
  2. Wiring E67 ECM for PWM Fans on 2007 TBSS
    By blades11b in forum E37, E38 & E67 PFI ECM's
    Last Post: September 19th, 2018, 07:31 AM
  3. 2007 TBSS electric fan programming
    By Stoichiometric in forum E37, E38 & E67 PFI ECM's
    Last Post: October 22nd, 2007, 05:10 PM
  4. 2007 Tbss tune help
    By Jakes4321 in forum E37, E38 & E67 PFI ECM's
    Last Post: September 13th, 2007, 01:31 PM
  5. Cant read file From 2007 TBSS
    Last Post: September 2nd, 2007, 02:03 PM
