Thread: OS#12597120 and Flex Fuel??
    Jun 2008
    Default OS#12597120 and Flex Fuel??
    I have a 2007 classic silverado, its factory flex fuel, but not actual sensor. Im currently installing the actual sensor but ive read on some other forums that its not as easy as just switching actual sensor from no to yes (b3102). Can someone help me with this?
    LS1B.ctz
    -John
    1991 RCSB 2WD Sierra LQ4 swap, 220/224 112 cam, Twin VSR 6766 turbos
    4L80e w/shift kit, PY 3600, and 3.73 gears.
    22 PSI and E85, 4300# with driver. 9.7@138, 1.47 sixty
    :drivin:
    Jun 2008
    Anybody!!??
    -John
    :drivin:
    We dont have E85 around here so never messed with that. But im sure they are talking about all the tables that have to do with the fueling and spark multipliers when more E is being seen.
    May 2014
    As mentioned already, a handful of tables such as spark blend factor doesnt appear to be defined. Is this a stock file / do you have stock tune file? If it's a factory FF vehicle (sounds like it is), this spark blend table will already be populated so it should "work", but quite likely you would want to fine-tune that table based on your setup.
    I can help you get those couple tables defined in this OS via cax file probably
    Jun 2008
    Quote Originally Posted by aaronc7 View Post
    Yes this is the the stock tune file, I've already added the flex fuel sensor to the truck. I still haven't tuned it yet, let me know what I'm missing if you would please!
    -John
    :drivin:
    May 2014
    See attached, I made a cax8 file that added a few FF params. From what I can tell, this file already has FF enabled. Just enable "sensor fitted" and make sure it's displaying alcohol content in the scanner.
    Then find the spark blend factor that I added in the Spark folder as well, so you can blend in spark as you need it based on E content.
    Put the cax8 file in ...\EFILive\V8\User Defined Cax8\LS1B folder. You'll need to use the V8 editor.
  1. E38 Flex Fuel
    By JuhaniLS1 in forum E37, E38 & E67 PFI ECM's
    Last Post: May 16th, 2017, 07:32 PM
  2. looking for a lq4 tune os 12597120
    By Lsjuan in forum Gen III V8 Specific
    Last Post: July 4th, 2015, 02:18 PM
  3. Can I convert to flex fuel?
    By JUSTASBC in forum Gen III V8 Specific
    Last Post: February 19th, 2015, 04:54 AM
  4. Flex fuel sensor
    By vzsv8 in forum Gen III V8 Specific
    Last Post: February 24th, 2009, 11:35 PM
  5. Converting a NON-Flex fuel vehicle to Flex fuel??
    By kbracing96 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2008, 06:15 AM
