Results 1 to 3 of 3
Thread: 4 degrees timing retard needed
    Jul 2006
    Default 4 degrees timing retard needed
    I have an 01 corvette ls1 , I need to retard the timing 4 degree's for my 100 shot wet nitrous. What table do I go to to retard it the 4 degree's? Any help would be highly appriciated. I am using EFI Live personal scan and tune updated to newest version...do not have wideband..The nitrous kicks in at WOT.
    Oct 2004
    You would generally go to the B5913 - High Octane table. Or if you are a Commercial or Workshop license owner you would probably want to use Custom OS V5. That allows you a table to retard timing when N20 kicks in. Could be worth the $150 upgrade cost if you aren't already Commercial
    Andrew
    EFILive Crew
    Jul 2006
    Thanks, it probably would be a good investment.
  1. Idling at -5 degrees timing=$ thrown away
    By killerbee in forum Duramax LLY
    Last Post: August 12th, 2009, 02:58 PM
  2. engine pinging! knock retard 4 degrees?
    By silverada4.8 in forum Gen III V8 Specific
    Last Post: April 27th, 2009, 12:03 AM
  3. need to retard timing under boost
    By JOHNGEAR in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 8th, 2008, 02:07 AM
  4. Timing retard
    By uaesands in forum E37, E38 & E67 PFI ECM's
    Last Post: August 25th, 2008, 10:25 PM
  5. Nitrous timing retard
    By PRAY in forum Gen III V8 Specific
    Last Post: December 12th, 2007, 06:49 AM
