Results 1 to 5 of 5
Thread: Idle +150 RPMS Over Commanded
    Senior Member blsnelling's Avatar
    Sep 2010
    Default Idle +150 RPMS Over Commanded
    For years, I haven't been able to achieve the idle RPMs like I wanted in my truck. Finally, I spent a couple hours this evening playing with the tune. No matter what I do, something is commanding the idle RPM to be 150 RPMs higher than I have commanded in the Desired Idle Speeds table. This is true for the RPMs in all four columns. I played with every table under Idle -> General. I finally gave up and lowered all numbers in that table by 150 and it finally idles where I want it to. In other words, I have to command an In P/N A/C Off RPM of 500 in order for it to idle at 650 RPMs. What gives?
    On another note, I've had issues with the A/C not wanting to run at idle ever since I put this mildly cammed LQ4 in here years ago. That's why you see all my A/C on RPMs as high as they are. Even at 1100 RPMs, it still sometimes doesn't want to keep the compressor on. I can't find anything in the tune that would cause this. Any ideas?
    '01 ECSB 4x4, '04 6.0L LQ4 Shortblock, 243 Heads Milled .035 11:1 Compression, Pac 1218 Springs, Yank PT3200 Stall, Comp Cam 220/224, .581/.581, 112LSA, LS7 Lifters, TBSS Intake Manifold, Edelbrock 3864 90mm T-Body, Doug Thorley LT Tri-Y ceramic headers, Flowmaster 50 SUV, LS1 e-fans, Airaid MIT, Complete valve body build up, 4.30:1 Gears, 33/12.50-17 Tires
    Can you post before and after tunes...
    Sep 2010
    This is the tune from before I figured out it was +150. My goal was to idle at 650 only when in idle and no AC. If we can figure out why the AC compressor doesn't want to run at normal idle, I'll bring the others down to something like 800.
    FYI, freon is not low and pressure cycling switch has been replaced twice with an AC Delco part.
    Truck_09_19_2022.ctz
    Mar 2021
    Your stall saver rpm is set to 800 across the board..
    It should be typically 100-150 rpm below the desired speed.
    This makes it kick in at 800 when you only want 650.
    Not sure of the overall effect, but my AC clutch drops out when the rpm goes below this setting to reduce engine load.
    I never set the value above the actual rpm, so I'm not sure if it will also bump the idle speed.
    B4603 is where you should set the idle speed.
    Try making these all 650rpm & set the stall saver to about 150 below the RPM value adjacent to that cell.
    Sep 2010
    Quote Originally Posted by Lonnies Performance View Post
    Very interesting.
  1. e38/t43 commanded idle issue
    By b18cls1 in forum E37, E38 & E67 PFI ECM's
    Last Post: April 2nd, 2015, 11:17 AM
  2. Replies: 8
    Last Post: September 16th, 2013, 08:15 AM
  3. Overtemping at idle or low RPMs
    By Naf in forum Gen III V8 Specific
    Last Post: August 7th, 2011, 11:22 PM
  4. shift rpms tis rpm or engine rpms
    By 69camaro5speed in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 25th, 2008, 07:01 AM
  5. Auto VE Idle Commanded AFR?
    By CGTMS in forum Gen III V8 Specific
    Last Post: May 12th, 2008, 08:37 AM
