Results 1 to 3 of 3
Thread: Looking for a Cal to Segment Swap
    Default Looking for a Cal to Segment Swap
    Hello, I have a 1950 Chevy 3100 we are wrapping up with a 2010 Based 5.3L and with a TKX 5 speed manual trans behind it. I have the VSS wires pinned into the PCM connector but cannot for the life of me get the VSS to actually read. I am guessing it has something to do with the PCM being an Auto based PCM. Wondering if there is any help or if anyone has a Matching OS cal from a Vette or Camaro that i can try to segment swap to get it working, unless there is another way to get this working that I am not aware of.
    Update: I have gotten the Speedo to read something, not I just have to figure out why the scale is so messed up It reads 60mph at 10mph and at 40mph it pegs 150mph on the gauge and reading via Scan tool. I am not sure where I need to adjust to make everything happy with this, but the idle wants to hang very high because of the speed it is seeing.
    Alright so now I have the issue remedied, I said screw it and just bypassed the PCM and ran the VSS wires direct to the Dakota Digital Module to get vehicle speed since it is apparently an issue for these computers to process a real VSS. What I am after now is a stock 4.8L/5.3L truck cal with a Manual Trans. I assume some sort of work truck cal with a 4.8L/ NV3500 trans setup or something along those lines if anyone has one Id greatly appreciate you sharing it.
  1. Need help with segment swap
    By 12sec.5.3 in forum Gen III V8 Specific
    Last Post: February 19th, 2018, 03:34 PM
  2. 4l80 swap with frost harness without segment swap
    By james workman in forum Conversions / Aftermarket Parts
    Last Post: March 10th, 2017, 04:12 PM
  3. Replies: 6
    Last Post: June 20th, 2016, 05:48 AM
  4. How do you do a segment swap?
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 8th, 2012, 08:18 AM
  5. Segment swap...Q's???
    Last Post: November 6th, 2007, 07:14 PM
