Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: Need help with no start issue
  1. #21
    Aug 2018
    Quote Originally Posted by andysc3 View Post
    awesome. thank you. Guess its time to take it off the blocks lol.
    If it starts up and revs all good....I would.
    Only way you'll get good data for tuning is driving it.
  2. #22
    Jan 2012
    Okay. So went for a drive. Afr was still pegged lean. Then got a reduced engine power. P0068 map/maf-throttle position correlation
    2011 Cadillac Escalade ESV. BTR 218/224 .553/.553 110LSA. Built 6L80 with 278mm Circle D 2800 stall converter.
  3. #23
    Jan 2012
    the dtc was set at frame 33000. my efi live wouldnt let me load the pid list you attached. there were a few spots where timing dropped to -15. other than that it was pretty good. need to fix some of the transmission tables. it didnt like the converter much.
  4. #24
    Jan 2012
    I do have some slight leaks on the exhaust slip connections on the y-pipe. Ordered some better clamps that will be here on Saturday
  5. #25
    Jan 2012
    would adjusting C0805/6 cure the P0068? below 30% throttle the expected change seem kinda low?
  6. #26
    Jan 2012
    Also thinking my wideband sensor may be bad. With leaving the key on for 30+ seconds then trying to start it. Could have damaged the ceramic inside the sensor.
  7. #27
    Jan 2012
    New exhaust clamps came in. While their not fully sealed its alot better than before. Most of the leaks are after the ypipe though. The new o2 sensor for bank 2 also came in. Was orginally scheduled for Monday so it was a nice surprise. Ordered a new bosch wideband sensor last night. Will hopefully have it by Tuesday or Wednesday. Should I enable the stft until the new wb sensor is here?
  8. #28
    Jan 2012
    I renabled stft and after about 30 seconds trims went to -25% and the idle started hunting real bad. Guess I'm going to have to wait until the new wb sensor comes in before I can do any more fuel tuning. Got the idle down to 800rpm with a base of 18* would go +/-50 rpms
  9. #29
    Jan 2012
    New bosch wbo2 came in. Got it swapped in. Went to load a new tune with the vve tables lowered in the idle areas but the battery was dead. Seems I forgot to unplug the v2 from the obd2 port along with below freezing temps the last few days. I have it on a charger. Will try again tonight when I get home.
  10. #30
    Jan 2012
    And I have a working wideband now. log showed I need to take an additional 20% out of the idle area on the vve table. got timing alittle better, might need to take an additional 1 or 2* out of the base idle timing. it's also wanting to hunt for the idle but not as bad as before.
  1. Cold start issue
    By 5557nut in forum Gen IV V8 Specific
    Last Post: June 3rd, 2021, 02:42 AM
  2. E38 no start issue
    By Hooter in forum E37, E38 & E67 PFI ECM's
    Last Post: April 21st, 2020, 11:40 AM
  3. Start/Post start issue!
    By IJ. in forum Gen IV V8 Specific
    Last Post: September 3rd, 2013, 02:55 PM
  4. LS7 Hot Start Issue
    By hapnermw in forum E37, E38 & E67 PFI ECM's
    Last Post: August 20th, 2009, 05:24 PM
  5. warm start issue
    By thomas walters in forum Gen IV V8 Specific
    Last Post: October 16th, 2007, 06:40 PM
