Results 1 to 10 of 13
Thread: Nov 15, 2022, V8.3.31 Beta Release
    Default Nov 15, 2022, V8.3.31 Beta Release
    V8.3.31 Public Beta Release
    Be careful when installing the beta software on your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. If you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V3/V2 device (when installing the latest beta firmware) and only install the EFILive beta software on a separate PC, laptop or virtual machine.
    Full Release Notes:
    DVersion Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V8 software: V8.3.31
    • FlashScan/AutoCal V3 Firmware: V3.00.100
    Download here:
    Known Limitations:
    Limitation #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Limitation #2: When opening CMF (CM2450B) Cummins 2022 tune files, the EFILive software will complain with the following message:
    That is expected and the message may be ignored. We have only added the option to open CMF 2022 stock files so that EFILive can flash stock files. EFILive cannot be used to update the check sums of modified files. Modified files cannot be flashed.
    Ignore the message if you are opening and flashing a 100% stock tune file. Do not attempt to flash a modified file, it will fail at the end of the flash and the vehicle will be left in a no-start condition until a stock file is flashed in.
    Workaround: None.
    Known Issues:
    None.
    Regards,
    The EFILive Team
    May 2010
    "Added Pro Tuning option to bypass flash restrictions on ECMs that cannot be identified, for the following ECM types: E01, E41, E88, E90, E93, E99 and T87A."
    Would you mind to illustrate this point please ?
    will there be future support for E90 or E99 ? 2022 GM trucks ?
    EFILive Tuner
    Those controllers are currently supported for flashing. Some tuners have requested to be able to flash their own custom** modified tune files that may not be "recognized" by the EFILive software as compatible with the target controller.
    With this new option the tuner can choose to override the built in EFILive protection and force the EFILive software to flash the ECM/TCM with the selected file.
    However that comes with the risk of bricking the controller - which is why it is only available with the Pro Tuning License.
    ** I.e. some tuners are working hard to figure out ways to bypass the built in security on those controllers. This option gives them greater flexibility to flash in data/files that may not be 100% expected/standard.
    Right now we (EFILive) don't have any plans to offer calibration mapping (i.e. editing) support for those controllers. However, they all support user defined calibration mapping via cax8 files. Some tuners may provide calibration mapping themselves. If they do, they can use the cax8 encryption option to sell those calibrations to other EFILive tuners while protecting their IP.
    The biggest problem right now is the digital signature protection that prevents those late model years from being flashed with custom files.
    Lifetime Member Road's Avatar
    Feb 2015
    When loading custom menu getting error below. This appeared with the last public release and still happening with new beta.
Name:	EFI live Error.PNG
    Quote Originally Posted by Road View Post
    Can you please log that as a support ticket here: https://service.efilive.com/new-ticket
    And please include the custom menu.
    Feb 2015
    Sent one, support been nonresponsive lately too
    Apr 2020
    any base stock files for these new suported ecu ?
    Jul 2003
    Quote Originally Posted by BYTES View Post
    You will likely need to get them from SPS and use the tool to generate a valid bin file for them.
    What ECM do you want a base calibration for?
    Apr 2020
    i would like base original files for efi for the new chevys ecu if possible
    E41 for example
    There's a new "Import from TIS" option that will import the encrypted/compressed TIS files from GM.
  1. Aug 27, 2022, V8.3.29 Beta Release (Updated Oct 20, 2022)
    Last Post: October 19th, 2022, 05:05 PM
  2. July 19, 2022, V8.3.27 Public Beta Release - Update 1
    Last Post: July 18th, 2022, 05:37 PM
  3. July 11, 2022, V8.3.26 Public Beta Release
    Last Post: July 10th, 2022, 12:08 PM
  4. June 22, 2022, V8.3.25 Public Beta Release
    Last Post: June 21st, 2022, 03:29 PM
  5. Public Release (Nov 2017)
    Last Post: December 16th, 2017, 06:53 AM
