Results 1 to 3 of 3
Thread: LS swapped S10 lean maxing out o2 sensor
    Lifetime Member mvvette97's Avatar
    Jul 2007
    Default LS swapped S10 lean maxing out o2 sensor
    Hi guys have a problem with running extremely lean. I got the 6.0 put back in the s10 due to pulling the heads and putting new lifters in. I was logging the idle and it started climbing in the trims to a point where it maxed out the drivers side and passenger side was not far behind. I thought the intake gaskets were leaking since I reused them so put a new set on and the same.I tried unhooking both o2 sensors to see what it would do Monitoring it with an installed stand alone wideband and it was reading 19 afr. It was actually running not bad. Any idea what could cause this? It was fine before. I did find on the shorty headers it was leaking at the header gasket and also down on the 3 bolt collector pretty bad. The O2 sensors are down stream of the leaks as well as the wideband sensor. Could the exhaust leaks of messed with the o2s making it go positive on the trims? If so I'm guessing it would mess with the wideband as well since they are both down about 8 inches from the leaks.Could it be not really lean and just being fooled to think it is from the leaks? Thats the only thing I can come up with.
    Dec 2016
    Exhaust leaks are bad. It will usually induce oxygen into the exhaust and tell the sensors you are falsely lean.
    Jul 2007
    that's what I was kinda thinking as well since I wasn't able to find any vacuum leaks at all. Hopefull that's all it is because I don't know what else it could be because it was fine before I pulled the heads and cam. Had a guy mention maybe it's something with the cam but I really don't think so. I have done many cam swaps and never seen any of them do this.
  1. '13 truck had LC9, swapped to LY6
    By Eliminator04 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 11th, 2020, 11:56 AM
  2. is anybody driving the L83 with 6L90E swapped into anything?
    By v8vegaman in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 26th, 2019, 05:25 PM
  3. L96 6.0 swapped into 2009 Suburban
    By Nver2loud in forum E37, E38 & E67 PFI ECM's
    Last Post: September 10th, 2016, 01:33 AM
  4. swapped engines not returning to 0 throttle
    By ls1mike in forum Gen III V8 Specific
    Last Post: April 20th, 2012, 01:49 PM
  5. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
