Results 1 to 7 of 7
Thread: maf
    Nov 2014
    Default maf
    on the ls1/99 c5 i see differences of up to 25 grams (about 10%) for up to 1 sec. between sae.maf and gm.maf, sae.maf usually being higher. which one to use?
    (i never paid attention to this, as im usually runnind sd.)
    edit: while were at it, what is gm.etctp? it seems to be lagging behind sae.tp quite a bit.
    Use GM.MAF.
    SAE.MAF is not quite the same as GM.MAF.
    Post log showing GM.ETCTP and and GM.TP and SAE.TP, these 3 are each different.
    For DBW use GM.ETCTP.
    Nov 2014
    please remind me: what is dbw?
    Dec 2016
    acronyms, bleh dbw as far as I know is Drive By Wire, electronic throttle.
    Nov 2014
    thanks. have always been using sae.tp (99 c5) but gm.etctp is consistently lagging by about 0.05 sec (on an average). why use that? (it goes up to 100% vs. 99.6% for sae.tp, but i cant see how that would matter.)
    from a log (stock tune): sae.maf 264, gm.maf 237, dyncylair 0.66, rpm 5957. should be 262g/s, so i guess sae.maf is closer. difference usually it not so large. another "extreme" point: 182/166 g/s. during a shift gm.maf seems to go higher (234/266. 9), however.
    so what is this, a logging phenomenon, how so? same signal, right? (i was logging at 5 hz.)
  1. ol maf tune or ve maf open loop and lambda question
    By 400ss in forum Gen III V8 Specific
    Last Post: February 1st, 2015, 07:12 AM
  2. Tuning changes going from 85mm MAF to LS7 or other 100mm MAF?
    By PRAY in forum E37, E38 & E67 PFI ECM's
    Last Post: November 21st, 2012, 02:11 AM
  3. Replies: 10
    Last Post: August 27th, 2009, 10:38 AM
  4. MAF Calibration..Why not use SAE MAF vs CYLAIR DMA
    Last Post: September 30th, 2008, 10:44 PM
  5. Set MAF limit to 1Hz, but MAF still working?!?!
    By TaTommy888 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2005, 07:02 AM
