Results 1 to 3 of 3
Thread: getting knock retard at idle. False?
    Lifetime Member mvvette97's Avatar
    Jul 2007
    Default getting knock retard at idle. False?
    I noticed today I was getting a little knock at idle on my 5.3 swapped s10. It has a bit of a noisy valvetrain with the cam so guessing the sensors are picking it up a little. Is there a way I can change the knock setting to not pick it up at idle only?
    Look at B6244.
    Higher numbers desensitize the knock sensors.
    Post log file.
  1. Knock knock, False knock? LS3 mutant in C5 car LS1 pcm
    By BHC5 in forum Gen III V8 Specific
    Last Post: July 6th, 2017, 08:14 AM
  2. Possible False Knock
    Last Post: May 13th, 2009, 12:32 AM
  3. What to do when you get false knock???
    Last Post: May 19th, 2008, 01:30 PM
  4. Knock Retard GM.KNKRET vs Retard Due to Knock GM.KR
    Last Post: March 9th, 2008, 03:18 AM
  5. False Knock?
    Last Post: April 9th, 2006, 01:27 PM
