Results 11 to 20 of 28
Thread: Dec 11, 2022, V8.3.32 Beta Release
    Jul 2003
    it is hard to see, i agree, but. i've had a few other ideas that hopefully get implemented... got to love the scanner ability. V8 is super powerful.
    That being said you can actually arrange the charts in whichever form you want. also the gauges could be made into a pseudo form of list (just takes a lot of time).
    Quote Originally Posted by Highlander
    +1.
    while not related to the beta & instead of starting a new thread. can you take a look at the 7.5 definition for t43 os 24256025 and see what is configured at the following address - 1F652A
    I have a cax file defining it as below but get a conflict, but i can make a change in the binary directly and do a compare & efi does not see any changes. (V8 runs fine, but im lazy and still use v7 format/editor)
    [D9812]
    ; Description
    DESC.001 = Remove requirement for a Tap Shift movement before enabling Manual Mode
    DESC.002 = Removes SPORTS MODE.
    DESC.003 =
    ; Seg Caption Major Minor Vis Dis 2D Grp
    VIEW = 4 "Up/Down Requirement" "Shift Control" "" 1 1 0 0
    ; Address(es) BitOff Bits Typ Inv
    ADDR = 1F652A 0 8 SED
    Jul 2003
    [D9812]
    ; Description
    DESC.003 =
    ADDR = 1F652A 0 8 SED 0
    ; Units Factor Offset Prec MinLimit MaxLimit MinUser MaxUser
    SI_SLOT = Enable/Disable 1.0 0 0 0 1 0 1
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    SI_ENUM = "1=Enable,0=Disable"
    IM_ENUM = "1=Enable,0=Disable"
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_ROW = .
    WORKS FINE
    yeah i know it works. :-)
    But, 7.5.48 gives an overlap error with stock defined parameter when it clearly doesn't.
    if i load a file with that 1 bit changed vs another, the editor does not show any file differences.
    Jul 2003
    Try my paste. it may just be a pasting error.
    tried from a blank cax file. copy/pasted your version same error.
    Are you running the latest 7.5 too?
    Jul 2003
    right now.. no.. i converted to v8. I will check v7
  9. #19
    Nov 2007
    I've added that option - turned out to be quite simple in the end.
    Using the [Identify] button skips the test results and DTC retrieval, it only takes about 1-2 seconds per module to display the details:
    Attachment 24292
    Hi Paul, what version was it added in? Was it the in this V8.3.32 link on the first page or the next build?
  10. #20
    Nov 2007
    Quote Originally Posted by kangsta View Post
    sorry, worked it out. It was under the "Read" button, the "Identify" button wasnt there for me
  1. Nov 15, 2022, V8.3.31 Beta Release
    Last Post: November 17th, 2022, 01:37 PM
  2. Aug 27, 2022, V8.3.29 Beta Release (Updated Oct 20, 2022)
    Last Post: October 19th, 2022, 05:05 PM
  3. July 11, 2022, V8.3.26 Public Beta Release
    Last Post: July 10th, 2022, 12:08 PM
  4. June 22, 2022, V8.3.25 Public Beta Release
    Last Post: June 21st, 2022, 03:29 PM
  5. Dec 2017, Beta Release 05
    Last Post: December 8th, 2017, 12:54 PM
