Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Dec 11, 2022, V8.3.32 Beta Release
    Default Dec 11, 2022, V8.3.32 Beta Release
    V8.3.32 Public Beta Release
    Be careful when installing the beta software on your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. If you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V3/V2 device (when installing the latest beta firmware) and only install the EFILive beta software on a separate PC, laptop or virtual machine.
    Full Release Notes:
    DVersion Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V8 software: V8.3.32
    • FlashScan/AutoCal V3 Firmware: V3.00.101
    Download here:
    Known Limitations:
    Limitation #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Limitation #2: When opening CMF (CM2450B) Cummins 2022 tune files, the EFILive software will complain with the following message:
    That is expected and the message may be ignored. We have only added the option to open CMF 2022 stock files so that EFILive can flash stock files. EFILive cannot be used to update the check sums of modified files. Modified files cannot be flashed.
    Ignore the message if you are opening and flashing a 100% stock tune file. Do not attempt to flash a modified file, it will fail at the end of the flash and the vehicle will be left in a no-start condition until a stock file is flashed in.
    Workaround: None.
    Known Issues:
    None.
    Regards,
    The EFILive Team
    Nov 2007
    Feature Request: "ECM Info" button/pane like in V7.5. I often use it to check a ECM without having to do a full read. Miss this feature in V7.5, it still works currently but has the popup about the flashscan firmware compatibility first.
    Quote Originally Posted by kangsta View Post
    Good idea, I'll add it to the "to do" list.
    Meanwhile, if you have a V3 device you can do this:
    Diagnostics -> F1: Display Info -> F1: Display VIN/Info
    That will display info for all detected modules, like this:
    I've added that option - turned out to be quite simple in the end.
    Using the [Identify] button skips the test results and DTC retrieval, it only takes about 1-2 seconds per module to display the details:
    Thanks!
    Dec 2016
    Nice
    Jul 2003
    awesome
    another thanks.
    Nov 2007
    Thanks! it looks like it was well received by all the "old hats" around the forum too. Glad I could contribute a useful idea
    would it be possible for the logger to show a large value from the pid.
    I.e logging trans it shows text Park, Neutral etc etc but it's small text. would it be possible to change them to a single Large Letter or Number. P,R,N,1,2,3,4,5,6 etc.
    Just so it's easier to see at a quick glance. I still have perfect vision but with the amount of data being shown it doesn't stand out as much.
  1. Nov 15, 2022, V8.3.31 Beta Release
    Last Post: November 17th, 2022, 01:37 PM
  2. Aug 27, 2022, V8.3.29 Beta Release (Updated Oct 20, 2022)
    Last Post: October 19th, 2022, 05:05 PM
  3. July 11, 2022, V8.3.26 Public Beta Release
    Last Post: July 10th, 2022, 12:08 PM
  4. June 22, 2022, V8.3.25 Public Beta Release
    Last Post: June 21st, 2022, 03:29 PM
  5. Dec 2017, Beta Release 05
    Last Post: December 8th, 2017, 12:54 PM
