Trying to idle up a 3.0L with no luck.
It will idle at target in gear but not in park. it ignores the desired idle speeds.
any ideas?
any ideas?
Here is the factory tune E39_0000
I made changes and tried E39_0001
i was grasping for straws after 3 hours of fooling with this so i started adding to the Torque response Commanded power tables and the Torque models. It either idled at 550 rpms when targeting 750 in P/N or it would go to 3000 rpms. Nothing inbetween.
