Results 1 to 5 of 5
Thread: tapping rev limiter slightly at 1-2 shift. LS swapped s10
    Lifetime Member mvvette97's Avatar
    Jul 2007
    Default tapping rev limiter slightly at 1-2 shift. LS swapped s10
    Been trying to get my s10 dialed in. It's running a cammed 5.3 engine. It seems to just barely tap the rev limiter right at the 1-2 shift at Wide open. My limiter is set to 6200 so hate to bump it up any more. What table can I change in the trans to make it shift just a bit sooner? Funny thing is I had an old wore out 6.0 in it before and it never did hit the limiter during the shift but this 5.3 does. this new engine seems to rev way faster than the old 6.0. It was down on power compared to this new engine. I would guess it's just revving too quick in first for the trans to keep up and make the shift in time. Figued I could command it to shift a little sooner to hopefully get the shift just below the limiter. The trans is a 4l80 as well.
    Post your tune.
    Also what gear ratio and tire size?
    What size cam?
    6200 is kinda low of a rpm for limiter.
    Transmission fluid level correct?
    Set your WOT Shift RPM and MPH a little lower and give it a try.
    Depending on your cam, intake, exhaust setup you could raise rev limiter up to 6800 and still be plenty safe. it might still be making power past 6200rpms.
    Dec 2016
    FYI, the rods may not break but those stock cast hyper pistons don't like to be above 6200 rpm very many times, beware.
    Quote Originally Posted by In-Tech View Post
    Really? Ive tuned cam'd 5.3 and 6.0's in mud trucks that hang out at 7200ish for an uncomfortably long time.
    I know the early small rods werent to keen on power but them pistons have been hanging in there. The Gen 4s we spin them up to 8600-8800 rpms in the drag cars.
    Dec 2016
    Sorry, I've seen multiples that others have turned up the rev limiter and ign timing nor preignition was the factor :( if they are looser than .0023 they will break with rpm, but then, how do you know. risk risk risk, not focking worth any of it.
  1. LS swapped S10 lean maxing out o2 sensor
    By mvvette97 in forum Gen III V8 Specific
    Last Post: December 4th, 2022, 03:47 AM
  2. Rev limiter
    By catman3126 in forum Duramax 2011+ LML / LGH
    Last Post: May 16th, 2016, 09:39 AM
  3. Hitting the rev limiter on the 2-3 shift at WOT...
    By waveoff in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 14th, 2007, 10:23 AM
  4. 97 C5 Rev Limiter ?
    By Kool C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2007, 11:28 AM
  5. rev limiter
    By CWR in forum Vortec V6/V8 Specific
    Last Post: July 4th, 2007, 04:40 PM
