Results 1 to 5 of 5
Thread: uneven long term fuel trims on my ls swapped s10
    Lifetime Member mvvette97's Avatar
    Jul 2007
    Default uneven long term fuel trims on my ls swapped s10
    was out doing a little tuning today and my long term trims are not even. My right bank it setting about -2 and the drivers bank is +3 or so. I can't get them to even up. I can't find any exhaust leaks or intake leaks. What could possibly cause this? I'm stumped
    Mar 2021
    Have you swapped the o2 sensors to see if the trims move with the sensor?
    Are you running single or dual exhaust?
    Are the trims consistent all the way across the table or only at cruise?
    Mine vary at times but seem to get closer as rpm & load increases.
    I partially blame the single exhaust which may have differing pulse tuning due to different lengths left to right before the merge point.
    Jul 2007
    I havent swapped the sensors but both a new. It has dual exhaust with an xpipe. At cruise they will get close but rarely get even. I just got in and it was running -3 and -1 but have seen it at -1 to -4 or -5. it seems to run well. Idle seems to be where the largest difference is
    Mar 2021
    2-3% is nothing to worry about in modified vehicles.
    If you are over 5% consistently, I would investigate, but random variations can be common at idle especially with larger cams.
    o2 sensor placement is usually less than ideal & may be more influenced by 1 cylinder in a given pipe.
    Swap O2 sensors across banks, we want to know if trims follow senors or not.
    A sensor being new does not necessarily mean it's ok
    How did you check for leaks (you are looking for air leaking in, not exhaust leaking out).
  1. Short/Long Term Fuel Trims...do these look ok?
    By kjlindgr in forum E37, E38 & E67 PFI ECM's
    Last Post: November 21st, 2014, 02:23 PM
  2. Quick question about Long Term Fuel trims
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: June 17th, 2011, 03:35 AM
  3. How to reset long term fuel trims?
    By Hulkss in forum Gen IV V8 Specific
    Last Post: November 8th, 2010, 04:25 AM
  4. Long Term fuel Trims..
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: July 25th, 2009, 03:23 PM
  5. Long term fuel trims issues
    By Kurtomac in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2008, 05:08 AM
