Results 1 to 7 of 7
Thread: LPG economy tuning
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Default LPG economy tuning
    I am about to do some basic changes of the calibration on a LS1 Statesman that runs on LPG. The owner just wants improved fuel economy.
    Any concepts different than a Petrol car.
    I am anaware of what type of system its running at this stage.
    Will my wideband a PLX M300 work with LPG and what are the desired afrs??
    Jan 2005
    You will need to know the stoich ratio for LPG. Might be able to find it in the B3601 or google. You may also want to do a little research on the LPG to become a little more familiar with it's properties.
    Bringing on DFCO a little sooner, and leaning out the cruise area should improve the fuel economy.
    Nov 2005
    Have been researching.
    Stoich is 15.5
    But the M300 will just say 14.63 same as usual.
    I wonder how they like timing compared to petrol. Higher octane i guess it may like more than usual.
    Jan 2005
    I would have thought the M300 would allow you to switch fuel types. Not sure if you will be able to use it if you can't set lamda. Or if you do use it, how it will effect the tune.
    Nov 2005
    Apparently it doesnt matter. 14.63 represents Lamda 1.0 so in truth 15.5 (stoich) for LPG will be displayed as 14.63 on the M300
    Jul 2003
    Try to maximize timing... tune for best power and/or throttle response regarding to timing and you will always get best fuel economy.
    Jun 2006
    How did you make out?
    10 deg at idle, then lots after?
    Propane likes compression so I who think you could use lots of advance under power. I run an old HIE ignition on another truck. The low idle timing helps keep it smooth at idle.
    Hypocrits make terrible world leaders
    1999 GMC 1500 RC SB 5.3 4L60E (1 rebuild)
    Trans-go shift, DJM 2-4, Hotchkis frt&rr
  1. Inst/Avg fuel economy gauge accuracy after tuning?
    By endo in forum Tuning For Economy
    Last Post: June 21st, 2009, 05:48 PM
  2. E38 fuel economy tuning
    By hymey in forum General (Petrol, Gas, Ethanol)
    Last Post: January 26th, 2009, 12:34 AM
  3. Tuning for Economy can be done several ways.
    By wait4me in forum Tuning For Economy
    Last Post: March 19th, 2008, 02:31 PM
  4. TM bad for good economy?
    By N0DIH in forum Tuning For Economy
    Last Post: March 5th, 2008, 03:44 PM
  5. Tuning for economy? This MUST include Auto Trannies then.
    By emarkay in forum Tuning For Economy
    Last Post: March 26th, 2007, 09:13 AM
