Results 1 to 10 of 16
Thread: scan v7.5 messed up
    Nov 2014
    Default scan v7.5 messed up
    i have learned long ago not to play around with this fragile software and not to touch any of the setting adjustments. but yesterday i nevertheless decided to change the black logging screen to white (to be able to print screen). while that was successfull the following happened:
    - pids (f8) is empty
    - data (f9) is empty
    - dashboads c is blank
    - chart properties is empty. i can click on an empty space and a pid appears, but scale/font are empty and wont accept any input.
    - other stuff stopped working, e.g. display ... (f1) opens some unrelated adobe document.
    - time stamp disappeared
    closing and reopening a file doesnt help, same thing. all new files are like that. previously open log-files i didnt touch work as usual.
    i then attempted the same on another laptop and weirdly enough exactly same thing, the newly opened files are useless.
    what happened? what can i do to make the logging software work again?
    Jul 2003
    7.5 is not fragile. It is complex. You can always open your dash pages or just delete your documents\efilive\v7.5 folder and start from scratch.
    I would suggest you copy that folder somewhere else so you can move things one by one and then just copy what you need like calc-pids and the such.
    Also, V7.5 is no longer supported, while it still works wonderfully the new software is v8. It is more powerful and nicer after you get used to it.
    Nov 2014
    so after investing some time i was able to fix it. what had happened is that in my attempt to get the screen white i apparently set the font to white and it became invisible. i had done dashboard/recall instal. default/reset ls1 and it did nothing (no idea what that does). so now i found edit/properties/recall and that fixed it. so upon further investigation: edit/properties/display/color can set it to black again.
    usually if i messed with the "complex" (nice word for it) settings and something like that happened i just opened a new file for logging and forgot about it. in this instance, however, this didnt help, all newly opened files were affected, i wonder why that is.
    short tutorial (maybe it helps some other "occasional user"):
    change font color: edit/properties/display→color
    change screen color: right click/chart properties/chart→color
    change frame color: right click/dash settings/backgroung color→color
    (just because you mention it: loading dashboard/dashpage has never worked. the software saves it but cant find it again, sais "file empty". i have been putting up with this for several years now. maybe one day, if i have nothing else to do, i find a solution even for that.)
    edit: "change screen color" only changes the main screen, the y-axis fields stay black. if anybody can explain how to change those, please do.
    Quote Originally Posted by dian View Post
    change y-axis color: right click/chart properties/Y-Axis (left)→color
    change y-axis color: right click/chart properties/Y-Axis (right)→color
    I just re-tested the V7.5 save dash page and save dashboard options and they seem to work fine. What seems to be the problem?
    P.S. I recommend using the V8 software, the dashboards are much easier to manage, save, import and export between users.
    Nov 2014
    the problem is: the software does not find the files it saved. it sais "file empty". this has been the case for 7 years and on 5 different devices/computers (or more).
    (i updated the software twice and will never do it again, as it has worked worse every time and required considerable effort to get it running again. while i never had problems on the tuning side im glad to have it logg at all but will first consider getting some other logging software should i have to update it again.)
    It sounds like you are not really interested in resolving the issue you describe.
    If you are actually interested in getting the problem solved, let me know and I am more than happy to help you get it working correctly.
    Nov 2014
    yes, please let me know what could be done about it. it doesnt matter if i save to a stick or the hard disc. (its not that im not interested, but rather that the time/effort i can put into it is limited.)
    thanks for the tip about the color change. it worked as you said. the problem here is that most of the other items in the list seem to be doing nothing.
    and while im complaining: right click/chart properties/font in dash "c" only changes the size of the numbers on the y-axis. the label and current value remain the same. (for years i thought this did nothing, now i see it changes the size between 8 and 12 only, maybe its going to be different next time.) in dash "b" its the other way around, the font chages the current value and label, the y-axis numbers stay the same. iv had instances where i enlarge one and the other shrank down to invisibility. can anything be done about that?
    (im sure you understand that in view of such and similar behaviour of the software the occasional user finally gives up trying to get a grip on it.)
    All the various colors change correctly when I tested it this morning.
    Which ones exactly do not cause any change? If you mean the "hatch" colors, then that could be because the hatch color is the same as the background color - in which case you'd need to change the hatch color to be different than the background color and select an actual hatch pattern - not just black.
    The X-axis font is simple and straight forward, just change that in the Chart Properties [Chart] tab page using the "X-Axis" [Font] button.
    If you enlarge the X-axis font you can make the X-axis vertical size larger by increasing the X-Axis Size so that the large font fits in the X-Axis.
    The Y-Axis font is a little different. By default the Y-Axis font is set to "Auto-Size" which means it will grow/shrink to fit the amount of text required to be displayed, down to a minimum of 6 points and up to the maximum of the font size set for each Y-Axis. If you change the width of the Y-Axis using the Size (left) and Size (right) options (or change the chart's actual size) then the Y-Axis fonts will enlarge or shrink to allow the text to fit.
    The size of the value is determined by how many digits you specify. The more digits you specify the smaller the font (if it is set to Auto-Size).
    On the [Series] tab page you can set each of the four Y-Axis fonts to "Auto-Size" or not.
    If they are not set to Auto-Size, then the font you have selected will be used at the size selected and the text will not change size, but it may get truncated.
    When you select the actual font using the [Font] button for one of the series (i.e. one of the Y-Axis) you can replicate that same font name and size (not color) to each of the other 3 series using the [Copy] button. It just saves entering the same font 4 times for each different series.
    The format option allows you to specify additional decimal points using the standard "C" format string %.xf where x is the number of digits you want displayed after the decimal point. So for 2 decimal places you would specify %.2f for 0 decimal places you would specify %.0f
    All of that is explained in the documentation on pages 126 and 127.
    As for the saving/loading of dash pages and/or dash boards, I'm really not following what the problem is that you describe.
    If you save a dash board as a file, are you saying that when you select the "Open dash board" option the software can't find the file that was previously saved? Or are you saying the when you select the file that was previously saved the software says that the file is empty?
    Hi dian,
    If you do proceed doing uninstall folliwed by reinstall, then before reinstalling delete the EFILive folder(s) under My Document or under Documents.
  1. Replies: 3
    Last Post: June 25th, 2012, 11:43 AM
  2. My V2 lcd is messed up... Been like this since new....
    By cainer70 in forum FlashScan V2
    Last Post: April 1st, 2011, 01:13 PM
  3. What have I messed up - LC-1 problem?
    By MyM8V8 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 24th, 2009, 02:12 AM
  4. Any news on the messed up scaling of H0101 TCM tun
    By harascho in forum Gen IV V8 Specific
    Last Post: January 8th, 2009, 09:05 PM
  5. Help Truck Wont Start - Flash messed up somehow?
    By BlownAlaskan in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 12:17 PM
