Results 1 to 9 of 9
Thread: This guy says keep original VE values when increasing displacement value
    Oct 2003
    Default This guy says keep original VE values when increasing displacement value
    I've time-marked his discussion so you go straight to the recommendation he is making.
    "How to setup a base fuel map for larger displacement LS engines"
    https://youtu.be/ftoMyfHPxlI?t=41
    He's saying copy the table of VE values and update to your new displacement.
    (Increasing Displacement in the software scales up the VE vales, as you probably know.)
    Then, he pastes the old VE values back into the VE table.
    I'm not understanding. If you increase the displacement value, and the VE values adjust as a result, that is not what is intended by software design?
    What is the logic behind changing the VE values back to the old displacement VE values? Help me understand the logic. Is he right or wrong?
    The displacement value does not affect VE or anything else, it is purely for documentation.
    Unless maybe HPT adjusts the VE table based on the change in displacement (I don't know if HPT does or does not do this).
    EFILive does not do this.
    I don't understand why he pastes the old VE table back in.
    Oct 2003
    Thanks, Joe. How have you been!
    Actually, a lot of guys responded over at LS1Tech and replied that what he is saying is B.S.
    I'd rather be blown, bored... AND stroked!
    Now: 447 CID (Corvette 427) , ATI Procharger D-1SC Supercharger
    Oct 2003
    Well... the conversation over there is evolving...
    https://ls1tech.com/forums/pcm-diagn...ent-value.html
    Quote Originally Posted by Black LS1 T/A View Post
    Hi Michael,
    I am well, I hope you and yours are all well.
    I'll take a look over there shortly.
    Your are correct in pointing this out:
    EFILive uses the cylinder volume to calculate the VE as a percentage.
    Changing the cylinder volume will change the VE percentages displayed in this table.
    After he increases the displacement (which causes the displayed VE% to drop), does he paste back the original VE% table (i.e. not the raw g.K/kPa table)...?
    Oct 2003
    Yep.
    He copies his VE values before changing displacement, then pasted them back in as a "starting point" for tuning the VE table. Another guy that used HP Tuners a long time backed him up and gave a history of how the software used to use percentages that would change after displacement was altered.
  1. Replies: 20
    Last Post: January 17th, 2012, 12:48 AM
  2. Displacement not on pull down
    By dennisscars in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: May 24th, 2009, 12:15 PM
  3. Displacement on Demand
    By Cougar281 in forum Gen IV V8 Specific
    Last Post: February 10th, 2008, 05:14 PM
  4. DESIAC_B values and MAF values keep trimming down. Help!
    By ArKay99 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 12th, 2005, 12:54 PM
