Results 1 to 1 of 1
Thread: Not running on all cylinders
    Feb 2019
    Default Not running on all cylinders
    My engine is a 2010 LS3 6.2L manual 6spd, E38 ecm, mafeless, long tube headers hi-ram intake Texas Speed stage 2 cam
    I just put a new harness in, went for a drive 2 weeks ago and it ran great. Pulled into the yard, parked it went to finish another vehicle. 3 hrs later went to pull the car into the shop and no start. It acted like vats but ran long before dying, like 8 to 10 sec, DTC P0204 comes n goes. #4 injector has 10 ohms continuity , 12.29v to connector. New plug and wire. Logs shows misfire on cyl #4. Even after swapping coils. I have to cycle key, press the pedal 3 times to start. Nothing jumps out as to why the misfire.
    I've attached tune, log. any help is appreciated, thanks.
    UPDATE 23022023:
    If I should start a new thread, please tell me.
    I got the LS3 running sorta. I have replaced all sensors...cam, crank, map, nb o2's, and intake o-rings.
    I started going backwards full-flashing tunes (5) till I got back to the original vats delete tuine in 2019. It took almost 30% TP to get it to fire but it did fire consistently3 times. Still getting the P0204 code, runs rough but runs. Held the peddle to 1500>2800...ran best above 2600.
    I saved 2 logs 2nd was after disable maf C0301,02 to get rid of the P0102 code.
    I am hoping someone has time to peruse these to see if you have an idea why it runs so rough or maybe I need to add some PID's.
    I do not have WB O2's connected...just haven't addre4ssed connecting them to the V2.
    Thanks for your time
    LS3 Manual 6 spd E38 os:12633056
    Texas Speed 1 7/8" headers w/3" exhaust
    Texas Speed cam 229/236 .629/.615 112 LSA
    Hi-Ram intake stock injectors 90mmTB
  1. Only firing on corner cylinders... 5.3
    By bubba68ss in forum Gen III V8 Specific
    Last Post: April 28th, 2016, 08:58 AM
  2. E38, FI, boost, cylinders cutting out. Help!
    By arubenstein in forum E37, E38 & E67 PFI ECM's
    Last Post: December 31st, 2014, 03:55 PM
  3. Cylinders filling with fuel!
    By camar0corey in forum Gen III V8 Specific
    Last Post: October 2nd, 2011, 11:38 AM
  4. Can you log knock for individual cylinders?
    Last Post: March 9th, 2008, 03:13 PM
  5. 2-3 cylinders down.Any answers?
    By SVR in forum General (Petrol, Gas, Ethanol)
    Last Post: July 22nd, 2005, 05:12 AM
Tags for this Thread
