Results 1 to 3 of 3
Thread: LML Not Staying Running Post Tune
    Jan 2023
    Default LML Not Staying Running Post Tune
    Hi All. New to Duramax and Forum, but have been tuning (consumer side) Fords for 10 years and never had any issues. Finally converted to a Duramax for my farm truck and bought EFI Live AutoCal V3 and a custom tune. Followed the directions to unplug throttle sensor, programmed the tune then fired her up. Ran fine for about 2 minutes then shut off. I can start it up every single time immediately after and move the truck so long as I dont use the accelerator. I can shift and idle will move me around driveway forward and back but as soon as accelerator is touched, it shuts off. Tuning company sent me 3 tunes and all the same behavior. 10 days now without a working truck because no stock was available due to no read ability on LML I guess. Anyone else run into this issue or know the best way to get my truck going again? Thanks so much.
    Dec 2016
    G'day,
    As an outside observer, I would disconnect the battery for a few minutes to basically hard re-boot the system. Since you have tried 3+ tunes, something odd going on.
    Jan 2023
    In case someone else has this issue, the way I got it to work was to unplug the air throttle sensor. My protocol said to unplug it, tune truck, then plug it back in but leaving it unplugged got it working just fine now. Thanks for all of the DM suggestions!
  1. 2016 LML Post injection disable
    By DieselAdam in forum Duramax 2011+ LML / LGH
    Last Post: July 13th, 2017, 12:34 PM
  2. Throttle body not staying open 100%
    By Z06Luke in forum Gen III V8 Specific
    Last Post: May 10th, 2016, 08:21 AM
  3. Replies: 111
    Last Post: August 12th, 2014, 03:25 AM
  4. Efi Live Tuner Not Staying Connected
    By lmn8636 in forum FlashScan V2
    Last Post: July 12th, 2013, 03:46 PM
  5. Post Injection Problem - DPF Delete enabled, Post Inj #2 still squirting!
    By dmaxhumvee in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 22nd, 2012, 03:28 AM
Tags for this Thread
